path: root/include/configs/tegra-common-post.h
2014-10-23Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2014-10-22dm: tegra: spi: Convert to driver modelSimon Glass
This converts the Tegra SPI drivers to use driver model. This is tested on: - Tegra20 - trimslice - Tegra30 - beaver - Tegra124 - dalmore (not tested on Tegra124) Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22tegra: clean-up useless defineMarcel Ziswiler
Wondering what exactly that one should bring (;-p). Looks like a remnant of the last commit 783e6a72b8278d59854ced41a4696c9a14abbb0b kconfig: move CONFIG_OF_* to Kconfig Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-08-09ARM: tegra: use new generic $bootcmdStephen Warren
Replace the custom $bootcmd with that from <config_distro_bootcmd.h>. There should be no functional change, since the new generic $bootcmd was derived strongly from tegra-common-post.h. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19ARM: tegra: set initrd_high so boot scripts workStephen Warren
During bootm/z, U-Boot relocates the DTB and initrd to high memory so they are out of the way of the kernel. On ARM at least, some parts of high memory are "highmem" and can't be accessed at early boot. To solve this, we need to restrict this relocation process to use lower parts of RAM that area accessible. For the DTB, an earlier patch of mine set CONFIG_SYS_BOOTMAPSZ. However, since some platforms have different restrictions on DTB and initrd location, that config option doesn't affect the initrd. We need to set the initrd_high environment variable to control the initrd relocation. Since we have carefully chosen the load addresses for the DTB and initrd (see comments in include/configs/tegraNNN-common.h re: values in MEM_LAYOUT_ENV_SETTINGS), we don't actually need any DTB or initrd relocation at all. Skipping relocation removes some redundant work. Hence, set both fdt_high and initrd_high to ffffffff which completely disables relocation. If the user does something unusual, such as using custom locations for the DTB/initrd load address or wanting to use DTB/initrd relocation for some reason, they can simply set these variables to custom values to override these environment defaults. With this change, cmd_sysboot works correctly for a filesystem created by the Fedora installer. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-06-19ARM: tegra: fix extlinux.conf search locationStephen Warren
extlinux.conf is stored in /boot/extlinux/extlinux.conf rather than /boot/extlinux.conf. Adjust Tegra's default boot scripts to use the correct location. This change aligns Tegra's boot scripts with rpi_b.h and also the location that the Fedora installer actually puts the file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-03-05ARM: tegra: implement bootcmd_pxeStephen Warren
This retrieves a PXE config file over the network, and executes it. This allows an extlinux config file to be retrieved over the network and executed, whereas the existing bootcmd_dhcp retrieves a U-Boot script. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-03-05ARM: tegra: rework boot scriptsStephen Warren
Update the common Tegra boot scripts in the default environment to a) Make use of the new "test -e" shell command to avoid some error messages. b) Allow booting using the sysboot command and extlinux.conf. This allows easy creation of boot menus, and provides a simple interface for distros to parameterize/configure the boot process. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-02-03ARM: tegra: clear $usb_need_init each bootStephen Warren
$usb_need_init prevents "usb start" from being run multiple times for each boot attempt, i.e. once for USB storage, another for PXE, and another for DHCP. However, the flag that's used to determine when to run "usb start" is never cleared, so a subsequent "boot" command will never probe for a freshly plugged in USB device. Fix this so that new USB devices will be probed once per boot attempt. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-02-03ARM: tegra: set env vars to indicate Cardhu A04 supportStephen Warren
The U-Boot "cardhu" build supports only revision 4 of the Cardhu board and later compatible revisions. Hence, set $board_name in the default environment to "cardhu-a04" rather than just "cardhu". The Linux kernel has separate DTs for Cardhu A02 and A04, although the former isn't really supported any more. Consequently, the kernel DT file that matches the U-Boot cardhu build is "tegra30-cardhu-a04.dtb" rather than "tegra30-cardhu.dtb". Set the $fdtfile default environment variable to reflect this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23tegra: i2c: Enable new CONFIG_SYS_I2C frameworkSimon Glass
This enables CONFIG_SYS_I2C on Tegra, updating existing boards and the Tegra i2c driver to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heiko Schocher <hs@denx.de>
2013-05-28tegra: Define CONFIG_SKIP_LOWLEVEL_INIT for SPL buildAxel Lin
Then we can get rid of the #ifdef CONFIG_TEGRA guard in cpu_init_crit. Signed-off-by: Axel Lin <axel.lin@ingics.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-03-25tegra114: add SPI driverAllen Martin
Add driver for tegra114 SPI controller. This controller is not compatible with either the tegra20 or tegra30 controllers, so it requires a new driver. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25spi: add common fdt SPI driver interfaceAllen Martin
Add a common interface to fdt based SPI drivers. Each driver is represented by a table entry in fdt_spi_drivers[]. If there are multiple SPI drivers in the table, the first driver to return success from spi_init() will be registered as the SPI driver. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-02-11tegra: don't hard-code LCD into default TEGRA_DEVICE_SETTINGSStephen Warren
Only add "lcd" into TEGRA_DEVICE_SETTINGS if CONFIG_VIDEO_TEGRA. Otherwise, "lcd" is meaningless. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-01-16Tegra30: Add/enable Cardhu build (T30 reference board)Tom Warren
This build is stripped down. It boots to the command prompt. GPIO is the only peripheral supported. Others TBD. include/configs/tegra-common.h now holds common config options for Tegra SoCs. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2012-12-19Merge remote-tracking branch 'u-boot/master' into u-boot-arm-mergedAllen Martin
Conflicts: README arch/arm/cpu/armv7/exynos/clock.c board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-11-20tegra: move TEGRA_DEVICE_SETTINGS to tegra-common-post.hAllen Martin
Move environment settings for stdin/stdout/stderr to tegra-common-post.h and generate them automaticaly based on input device selection. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2012-11-19tegra: use generic fs commands in BOOTCOMMANDStephen Warren
Modify tegra-common-post.h's BOOTCOMMAND definition to use the generic filesystem command load rather than separate fatload and ext2load. This removes the need to iterate over supported filesystem types in the boot command. This requires editing all board config headers to enable the new commands. The now-unused commands are left enabled to assue backwards compatibility with any user scripts. Boards (all from Avionic Design) which define custom BOOTCOMMAND values are not affected. Signed-off-by: Stephen Warren <swarren@nvidia.com> tegra generic fs cmds fixup Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-29ARM: tegra: use standard variables to define load addressesStephen Warren
Currently, Tegra's default environment uses non-standard variables to define where boot scripts should load the kernel, FDT, and initrd. This change both changes the variable names to match those described in U-Boot's README, and shuffles their values around a little so that the values make a little more sense; see comments in the patch for rationale behind the values chosen. Note that this patch does remove the old non-standard variable "fdt_load" from the default environment, so this patch requires people to change their boot scripts. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-29ARM: tegra: define CONFIG_SYS_BOOTMAPSZStephen Warren
This define indicates the size of the memory region where it is safe to place data passed to the Linux kernel (ATAGs, DTB, initrd). The value needs to be: a) Less than or equal to RAM size. b) Small enough that the area is not within the kernel's highmem region, since the kernel cannot access ATAGs/DTB/initrd from highmem. c) Large enough to hold the kernel+DTB+initrd. 256M seems large enough for (c) in most circumstances, and small enough to satisfy (a) and (b) across any possible Tegra board. Note that the user can override this value via environment variable "bootm_mapsize" if needed. The advantage of defining BOOTMAPSZ is that we no longer need to define variable fdt_high in the default environment. Previously, we defined this to prevent the DTB from being relocated to the very end of RAM, which on most Tegra systems is within highmem, and hence which would cause boot failures. A user can still define this variable themselves if they want the FDT to be either left in-place wherever loaded, or copied to some other specific location. Similarly, there should no longer be a strict requirement for the user to define initrd_high if using an initrd. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15tegra: enable CONFIG_CMD_PARTStephen Warren
This is extremely likely to be used from the boot.scr that Tegra's default bootcmd locates and executes. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
