path: root/include/configs/tec.h
2015-03-04ARM: tegra: move common config defines centrallyStephen Warren
All boards need CONFIG_BOARD_EARLY_INIT_F, and many actively need CONFIG_BOARD_LATE_INIT. Move both of these into tegra-common.h so that board config headers don't need to repeatedly define them. Later commits will add new code in board_late_init() which applies to all boards, so CONFIG_BOARD_LATE_INIT should be enabled for all Tegra boards. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2013-04-15Tegra: TEC: Enable boot script supportThierry Reding
Boot script support brings TEC in line with other Tegra boards. To enable booting a Linux kernel with initial ramdisk, also include support for the new FIT image type. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14ARM: tegra: enable a common set of disk-related commands everywhereStephen Warren
Enable a common set of partition types, filesystems, and related commands in tegra-common.h, so that they are available on all Tegra boards. This allows boot.scr (loaded and executed by the default built-in environment) on those boards to assume that certain features are always available. Do this in tegra-common.h, so that individual board files can undefine the features if they really don't want any of them. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-01-16tegra: remove custom TEGRA_DEVICE_SETTINGS for board filesMarc Dietrich
TEGRA_DEVICE_SETTINGS lives now in tegra-common-post.h. This removes custom TEGRA_DEVICE_SETTINGS for all tegra boards providing video output, except seaboard, which was fixed by Stephen already. Cc: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Marc Dietrich <marvin24@gmx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-01-16tegra: Enable LCD on TECThierry Reding
The TEC ships with a 7" LCD panel that provides a resolution of 800x480 pixels. Add a corresponding panel description to the device tree and enable LCD support in the configuration. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Remove unnecessary CONFIG_SYS_NAND_BASESimon Glass
Now that we are using the new CONFIG_SYS_NAND_SELF_INIT setup, we don't need CONFIG_SYS_NAND_BASE. Punt it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-09-07tegra: Enable NAND on TECThierry Reding
This commit enables NAND support on the Tamonten Evaluation Carrier and adds the corresponding device tree nodes. Furthermore, the U-Boot environment can now be stored in NAND. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: tec: add tegra20-common-post.hAllen Martin
Add tegra20-common-post.h to be consistent with other tegra20 boards. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-09tegra: Add Tamonten Evaluation Carrier supportThierry Reding
The Tamonten Evaluation Carrier is an evaluation board for the Tamonten processor board. More information is available here: http://www.avionic-design.de/en/products/nvidia-tegra-tamonten-system-en/nvidia-tegra-tamonten-evboard-en.html Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
