path: root/include/configs/tec-ng.h
2015-08-05configs: Remove CONFIG_SERIAL_MULTIStephen Warren
This config option isn't used anywhere at all. Remove all places that define/enable the option. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-03-04ARM: tegra: move common config defines centrallyStephen Warren
All boards need CONFIG_BOARD_EARLY_INIT_F, and many actively need CONFIG_BOARD_LATE_INIT. Move both of these into tegra-common.h so that board config headers don't need to repeatedly define them. Later commits will add new code in board_late_init() which applies to all boards, so CONFIG_BOARD_LATE_INIT should be enabled for all Tegra boards. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2013-12-18ARM: tegra: Add the Tamonten™ NG Evaluation Carrier boardAlban Bedel
Add support for the new Tamonten™ NG platform from Avionic Design. Currently only I2C, MMC, USB and ethernet have been tested. Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
