The architecture is currently unmaintained, remove.
Cc: Benjamin Matthews <mben12@gmail.com>
Cc: Chong Huang <chuang@ucrobotics.com>
Cc: Dimitar Penev <dpn@switchfin.org>
Cc: Haitao Zhang <hzhang@ucrobotics.com>
Cc: I-SYST Micromodule <support@i-syst.com>
Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de>
Cc: Martin Strubel <strubel@section5.ch>
Cc: Peter Meerwald <devel@bct-electronic.com>
Cc: Sonic Zhang <sonic.adi@gmail.com>
Cc: Valentin Yakovenkov <yakovenkov@niistt.ru>
Cc: Wojtek Skulski <info@skutek.com>
Cc: Wojtek Skulski <skulski@pas.rochester.edu>
Move this in to Kconfig with a default of 115200.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[trini: Run moveconfig.py, reword commit slightly]
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
Correct spelling of "U-Boot" shall be used in all written text
(documentation, comments in source files etc.).
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
NET_RANDOM_ETHADDR depends on lib/rand.c. This patch adds dependency to
Kconfig to ensure that library is also compiled.
Remove the definitions from Blackfin boards' include/configs.
Remove the calls to net_random_ethaddr() that some boards and some
drivers are calling. This is now implemented inside of net/eth.c
Enable the feature for all boards that previously enabled it.
Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part)
Series-changes: 2
-Fixed bfin build errors
We really don't want boards defining fixed MAC addresses in their config
so we just remove the option to set it in a fixed way. If you must have
a MAC address that was not provisioned, then use the random MAC address
functionality.
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
If this option is enabled, the objects under lib/ directory
are compiled with speed optimization, not size optimization.
(Currently, only used by some Blackfin boards.)
bfin_gen_rand_mac() uses __DATE__ as the seed for random ethernet
address. This makes the build non-deterministic.
In the first place, it should not be implemented as a Bfin-specific
function. Use eth_random_addr() instead.
Cc: Sonic Zhang <sonic.zhang@analog.com>
Many (but not all) of Blackfin boards give -O2 option
to compile under lib/ directory.
That means lib/ should be speed-optimized,
whereas other parts should be size-optimized.
We want to keep the same behavior,
but do not want to parse board/*/config.mk again and again.
We've got no choice but to invent a new method.
CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED, if it is enabled,
gives -O2 flag only for building under lib/ directory.
Dirty codes which I had marked as "FIX ME"
in board/${BOARD}/config.mk have been deleted.
Instead, CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED has been
defined in include/configs/${BOARD}.h.
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code.
The CONFIG_BFIN_CPU option is largely used in the build system, so move
it out of the board config.h and into the board config.mk. It'd be nice
to keep everything in the config.h, but the patch to extract that value
early was rejected.
Acked-by: Heiko Schocher <hs@denx.de>
Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at>
