This board has not been converted to CONFIG_DM_MMC by the deadline.
Remove it.
Cc: Stefan Roese <sr@denx.de>
Cc: Tapani Utriainen <linuxfae@technexion.com>
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_SPL_NAND_BASE
CONFIG_SPL_NAND_IDENT
CONFIG_SPL_NAND_DRIVERS
CONFIG_SPL_NAND_ECC
CONFIG_SPL_NAND_SIMPLE
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
There is no real need to exactly define space for saving patterns for
alternate memory test. It is much easier to allocate space on the stack and
use it instead of trying to find out space where pattern should be saved.
For example if you want to test the whole DDR memory you can't save patter
to DDR and you need to find it out. On Xilinx devices DDR or OCM addresses
were chosen but that means that OCM needs to be mapped and U-Boot has
access permission there.
It is easier to remove this limitation and simply save it on stack because
it is very clear that memory test can't rewrite U-Boot and U-Boot has also
full access to memory where runs from.
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Currently "bootcmd" does not work as intended but instead prints MMC usage
information and goes directly to "nandboot".
Follow what the commit 669681104daa ("configs: Fix usage of mmc rescan")
does for other boards prior to support for TechNexion TAO3530 SoM was
added.
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_TWL4030_LED
CONFIG_TWL4030_INPUT
This also removes dead references to:
CONFIG_TWL4030_KEYPAD
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_SYS_NAND_ADDR is defined and never referenced. This patch
removes the dead code.
CONFIG_MTD_PARTITIONS
CONFIG_MTD_DEVICE
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
[trini: Re-run migration after also including CMD_MEMTEST]
CONFIG_CONS_INDEX
We have existing entries for this option in a number of places, with
different guards on them. They're also sometimes used for things not
directly inside of the serial driver. First, introduce a new symbol to
guard the use of CONFIG_CONS_INDEX, so that in the case where we don't
need this for the serial driver, but for some other use, we can still do
it. Next, consolidate all of these into the single entry in
drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that
we can imply a correct value here to make the defconfig side of this
smaller.
[trini: Rework a lot of the logic here, such that I took authorship from
Adam, but kept his S-o-B line]
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
Migrate the option CONFIG_SPL_FRAMEWORK and make this gate most of the
current set of options we have in Kconfig. We will need to have some
options available for SPL and !SPL_FRAMEWORK so this is important. In a
few cases we re-order existing options so that we have less escapes from
the SPL_FRAMEWORK guard.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
CONFIG_SYS_OMAP24_I2C_SLAVE
CONFIG_SYS_OMAP24_I2C_SPEED
Reviewed-by: Paul Kocialkowski <contact@paulk.fr>
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
CONFIG_NAND_MXC
CONFIG_NAND_OMAP_GPMC
CONFIG_NAND_OMAP_GPMC_PREFETCH
CONFIG_NAND_OMAP_ELM
CONFIG_SPL_NAND_AM33XX_BCH
CONFIG_SYS_NAND_BUSWIDTH_16BIT
[trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues,
add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT]
The USB Ethernet gadget option has not yet been moved to Kconfig, let's
deal with that.
Reviewed-by: Ćukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
CONFIG_EMIF4
CONFIG_SDRC
Reviewed-by: Stefano Babic <sbabic@denx.de>
In mancy cases both CONFIG_ENV_OFFSET and CONFIG_ENV_ADDR point
to an otherwise-unused SMNAND_ENV_OFFSET.
This patch will set both CONFIG_ENV_OFFSET and CONFIG_ENV_ADDR to
whatever value was defined by SMNAND_ENV_OFFSET.
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
This is not a valid option. Drop it.
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be
equal to CONFIG_SYS_CBSIZE in numerous configuration files.
We remove such definitions in two situations:
- CONFIG_SYS_CBSIZE is otherwise not defined in the board
configuration file, which means the default value of
CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value
of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is
larger.
- CONFIG_SYS_CBSIZE is defined in the board configuration file, but
to a value equal or less than 512. In this case, the default value
of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it
is equal or larger.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Now that include/config_fallbacks.h define a sane fallback for
CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all
configurations that were using the default value.
Now that the fallback value of CONFIG_SYS_PBSIZE in
include/config_fallbacks.h has been adjusted, remove its definition
from a large number of board configuration files.
CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all
[trini: Drop <config.h> from stih410-b2260.h]
CONFIG_SPL_OMAP3_ID_NAND
CONFIG_OMAP3_SPI
[trini: Minor comment tweaks]
With the hierarchical defaults set up, we remove these from the header
files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits
the changes.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_SYS_I2C_OMAP24XX
The driver is for all boards 24XX and up, so let's eliminate the
extra option called CONFIG_SYS_I2C_OMAP34XX since the driver checks
for CONFIG_OMAP34XX we don't need CONFIG_SYS_I2C_OMAP34XX.
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
Now that EHCD does not use CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS,
remove it in all boards' config files.
Tested-by: Stefan Roese <sr@denx.de>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
CONFIG_SPL_BOARD_INIT
Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
[trini: Update the Kconfig logic]
Follow the exiting logic for the i.MX options when migrating this
option.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
In order to be able to migrate the various SoC EHCI CONFIG options we
first need to finish the switch from CONFIG_USB_EHCI to
CONFIG_USB_EHCI_HCD.
The symbols CONFIG_OMAP3_GPIO_X control if we enable the clocks for a
given GPIO bank in U-Boot. select the required banks for each target.
In some cases we need to also migrate from CONFIG_USB_EHCI (deprecated,
in include/configs/) to CONFIG_USB_EHCI_HCD as we only require the GPIO
bank to be enabled if USB is also enabled.
