CONFIG_CMD_SATA
CONFIG_CMD_IRQ
CONFIG_CMD_ERRATA
Move this in to Kconfig with a default of 115200.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[trini: Run moveconfig.py, reword commit slightly]
configs/ls1046aqds_defconfig
configs/ls1046aqds_nand_defconfig
configs/ls1046aqds_qspi_defconfig
configs/ls1046aqds_sdcard_ifc_defconfig
configs/ls1046aqds_sdcard_qspi_defconfig
configs/ls1046ardb_emmc_defconfig
configs/ls1046ardb_qspi_defconfig
configs/ls1046ardb_sdcard_defconfig
Enable IFC from Kconfig.
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
These two macros are used for the same thing, the total number of DDR
controllers for a given SoC. Use SYS_NUM_DDR_CTRLS in Kconfig and
merge existing usage.
Signed-off-by: York Sun <york.sun@nxp.com>
Use option NUM_DDR_CONTROLLERS in ddr Kconfig and clean up existing
usage in ls102xa and fsl-layerscape. Remove all powerpc macros in
config header and board header files.
Create driver/ddr/fsl/Kconfig and move existing options. Clean up
existing macros.
[trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s]
Use Kconfig option for E500 and E500MC macros.
Some header files have this macro defined conditionally and
redefined unconditionally. Remove all existing definitions.
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig
to use that.
[trini: Re-generate configs and include/configs/ changes]
Add 'PCI' as a menu option and migrate all existing users.
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
For e6500 and e5500 SoCs, it was intended to put init_ram address in
ccsr reserved space. It is no longer true since SerDes module took the
space. Move it to another reserved space at CCSR + 0x03c000.
Signed-off-by: York Sun <yorksun@freescale.com>
Move config for the E1000 Ethernet driver to Kconfig and tidy up affected
boards.
them from include/configs.
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed
from the configs.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
This patch converts the following boards to use generic board: MPC8536DS,
MPC8572DS, MPC8641HPCN, p1_p2_rdb_pc, corenet_ds, t4qds, B4860QDS. It has
been tested on NOR boot on MPC8536DS, MPC8572DS, P1021RDB, P4080DS,
P5020DS, P5040DS, P3041DS, T4240QDS, B4860QDS.
CC: Ying Zhang <b40530@freescale.com>
CC: Prabhakar Kushwaha <prabhakar@freescale.com>
CC: Haijun.Zhang <Haijun.Zhang@freescale.com>
CC: Scott Wood <scottwood@freescale.com>
CC: Shaohui Xie <Shaohui.Xie@freescale.com>
Add support of 2 stage NAND/SD boot loader using SPL framework.
PBL initialise the internal SRAM and copy SPL, this further
initialise DDR using SPD and environment and copy u-boot from
NAND/SD to DDR, finally SPL transfer control to u-boot.
NOR uses CS1 instead of CS2 when NAND boot, fix it.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
U-boot binary size has been increased from 512KB to 768KB.
So update CONFIG_SYS_MONITOR_LEN to reflect the same.
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk
because all target boards with mpc85xx cpu define it.
u-boot binary size for Freescale mpc85xx platforms is 512KB.
This has been reached to upper limit for some of the platforms causig
linker error.
So, Increase the u-boot binary size to 768KB.
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years
ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should
care about this parameter or it should be gone completely.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs.
The similar DDR controllers will be used for ARM-based SoCs.
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Add emulator support for T4240. Emulator has limited peripherals and
interfaces. Difference between emulator and T4240QDS includes:
ECC for DDR is disabled due the procedure to load images
No board FPGA (QIXIS)
NOR flash has 32-bit port for higher loading speed
IFC and I2C timing don't really matter, so set them fast
No ethernet
CONFIG_PHYS_64BIT is always defined for t4qds. Removed unused #ifdef.
Move CONFIG_FSL_CORENET define to config_mpc85xx.h. It is not board
specific feature and belongs to SoC header.
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to fsl_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
When a T4 board boots from SRIO or PCIE, it needs to finish these processes:
1. Set all the cores in holdoff status.
2. Set the boot location to one PCIE or SRIO interface by RCW.
3. Set a specific TLB entry for the boot process.
4. Set a LAW entry with the TargetID of one PCIE or SRIO for the boot.
5. Set a specific TLB entry in order to fetch ucode and ENV from
master.
6. Set a LAW entry with the TargetID one of the PCIE ports for
ucode and ENV.
7. Slave's u-boot image should be generated specifically by
make xxxx_SRIO_PCIE_BOOT_config.
This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
For more information about the feature of Boot from SRIO/PCIE, please
refer to the document doc/README.srio-pcie-boot-corenet.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
T4 can support the feature of Boot from SRIO/PCIE, and the macro
"CONFIG_SRIO_PCIE_BOOT_MASTER" will enable the master module of this feature
when building the u-boot image.
You can get some description about this macro in README file, and for more
information about the feature of Boot from SRIO/PCIE, please refer to the
The pci_indirect.c file is always compiled when
CONFIG_PCI is defined although the indirect PCI
bridge support is not needed by every board.
Introduce a new CONFIG_PCI_INDIRECT_BRIDGE
config option and only compile indirect PCI
bridge support if this options is enabled.
Also add the new option into the configuration
files of the boards which needs that.
Compile tested for powerpc, x86, arm and nds32.
MAKEALL results:
powerpc:
--------------------- SUMMARY ----------------------------
Boards compiled: 641
Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB )
Note: the warnings for ELPPC and MPC8323ERDB are present even
without the actual patch.
x86:
Boards compiled: 1
arm:
Boards compiled: 311
nds32:
Boards compiled: 3
Cc: Tom Rini <trini@ti.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
T4160 is a subset of T4240. Merge them in config_mpc85xx.h to simplify
the defines. Also move CONFIG_E6500 out of t4qds.h into config_mpc85xx.h.
