path: root/include/configs/t4qds.h
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-01powerpc: configs: Fix init_ram physical address for several boardsYork Sun
For e6500 and e5500 SoCs, it was intended to put init_ram address in ccsr reserved space. It is no longer true since SerDes module took the space. Move it to another reserved space at CCSR + 0x03c000. Signed-off-by: York Sun <yorksun@freescale.com>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2014-05-13powerpc/freescale: Convert selected boards to generic board architectureYork Sun
This patch converts the following boards to use generic board: MPC8536DS, MPC8572DS, MPC8641HPCN, p1_p2_rdb_pc, corenet_ds, t4qds, B4860QDS. It has been tested on NOR boot on MPC8536DS, MPC8572DS, P1021RDB, P4080DS, P5020DS, P5040DS, P3041DS, T4240QDS, B4860QDS. Signed-off-by: York Sun <yorksun@freescale.com> CC: Ying Zhang <b40530@freescale.com> CC: Prabhakar Kushwaha <prabhakar@freescale.com> CC: Haijun.Zhang <Haijun.Zhang@freescale.com> CC: Scott Wood <scottwood@freescale.com> CC: Shaohui Xie <Shaohui.Xie@freescale.com>
2014-04-22powerpc/T4QDS: add two stage boot of nand/sdShaohui Xie
Add support of 2 stage NAND/SD boot loader using SPL framework. PBL initialise the internal SRAM and copy SPL, this further initialise DDR using SPD and environment and copy u-boot from NAND/SD to DDR, finally SPL transfer control to u-boot. NOR uses CS1 instead of CS2 when NAND boot, fix it. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc/mpc85xx:Update MONITOR_LEN for 768KB u-boot sizePrabhakar Kushwaha
U-boot binary size has been increased from 512KB to 768KB. So update CONFIG_SYS_MONITOR_LEN to reflect the same. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-24powerpc: mpc85xx: move CONFIG_MPC85xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk because all target boards with mpc85xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-21powerpc/mpc85xx:Increase binary size for P, B & T series boards.Prabhakar Kushwaha
u-boot binary size for Freescale mpc85xx platforms is 512KB. This has been reached to upper limit for some of the platforms causig linker error. So, Increase the u-boot binary size to 768KB. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-08-09powerpc/T4240EMU: Add T4240EMU targetYork Sun
Add emulator support for T4240. Emulator has limited peripherals and interfaces. Difference between emulator and T4240QDS includes: ECC for DDR is disabled due the procedure to load images No board FPGA (QIXIS) NOR flash has 32-bit port for higher loading speed IFC and I2C timing don't really matter, so set them fast No ethernet Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/t4qds: cleanup board header fileYork Sun
CONFIG_PHYS_64BIT is always defined for t4qds. Removed unused #ifdef. Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/corenet: Move CONFIG_FSL_CORENET out of board header fileYork Sun
Move CONFIG_FSL_CORENET define to config_mpc85xx.h. It is not board specific feature and belongs to SoC header. Signed-off-by: York Sun <yorksun@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-20powerpc/t4qds: Slave module for boot from SRIO and PCIELiu Gang
When a T4 board boots from SRIO or PCIE, it needs to finish these processes: 1. Set all the cores in holdoff status. 2. Set the boot location to one PCIE or SRIO interface by RCW. 3. Set a specific TLB entry for the boot process. 4. Set a LAW entry with the TargetID of one PCIE or SRIO for the boot. 5. Set a specific TLB entry in order to fetch ucode and ENV from master. 6. Set a LAW entry with the TargetID one of the PCIE ports for ucode and ENV. 7. Slave's u-boot image should be generated specifically by make xxxx_SRIO_PCIE_BOOT_config. This will set SYS_TEXT_BASE=0xFFF80000 and other configurations. For more information about the feature of Boot from SRIO/PCIE, please refer to the document doc/README.srio-pcie-boot-corenet. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/t4qds: Enable master module for Boot from SRIO and PCIELiu Gang
T4 can support the feature of Boot from SRIO/PCIE, and the macro "CONFIG_SRIO_PCIE_BOOT_MASTER" will enable the master module of this feature when building the u-boot image. You can get some description about this macro in README file, and for more information about the feature of Boot from SRIO/PCIE, please refer to the document doc/README.srio-pcie-boot-corenet. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-05-24powerpc/T4160: Merge T4160 and T4240 in config_mpc85xx.hYork Sun
T4160 is a subset of T4240. Merge them in config_mpc85xx.h to simplify the defines. Also move CONFIG_E6500 out of t4qds.h into config_mpc85xx.h. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-24T4240/ramboot: enable PBL tool for T4240Shaohui Xie
Added a default RCW(1_28_6_12) and PBI configure file for T4240, so it can use PBL tool to produce the ramboot image. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14T4240/net: use QSGMII card PHY address by defaultShaohui Xie
Use QSGMII card PHY address as default SGMII card PHY address, QSGMII card PHY address is variable depends on different slot. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14t4240qds/eth: fixup ethernet for t4240qdsShengzhou Liu
1, Implemented board_ft_fman_fixup_port() to fix port for kernel. 2, Implemented fdt_fixup_board_enet() to fix node status of different slots and interfaces. 3, Adding detection of slot present for XGMII interface. 4, There is no PHY for XFI, so removed related phy address settings. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc: Add T4160QDSYork Sun
T4160QDS shares the same platform as T4240QDS. T4160 is a low power version of T4240, with eight e6500 cores, two DDR3 controllers, and slightly different SerDes protocols. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/t4240qds: Add voltage ID supportYork Sun
T4240 has voltage ID fuse. Read the fuse and configure the voltage correctly. Core voltage has higher tolerance on over side than below. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/t4240qds: fix XAUI card PHY addressShaohui Xie
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-14powerpc/t4240qds: Fix SPI flash typeShaohui Xie
T4240QDS uses a SST instead of SPANSION SPI flash. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-30powerpc/t4240qds: Update IFC timing for NOR flashYork Sun
Relax parameters to give address latching more time to setup. Tighten parameters to make it overall faster. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-01-30boards/T4240qds:Fix IFC AMASK init as per FPGA register spacePrabhakar Kushwaha
T4240QDS's QIXIS FPGA has 4k register space size and IFC controller's Address Mask Registers is initialised 64K size. So Fix the Address Mask Register initilisation as 4K Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22powerpc/t4qds: Add T4QDS boardYork Sun
The T4240QDS is a high-performance computing evaluation, development and test platform supporting the T4240 QorIQ Power Architecture™ processor. SERDES Connections 32 lanes grouped into four 8-lane banks Two “front side” banks dedicated to Ethernet Two “back side” banks dedicated to other protocols DDR Controllers Three independant 64-bit DDR3 controllers Supports rates up to 2133 MHz data-rate Supports two DDR3/DDR3LP UDIMM/RDIMMs per controller QIXIS System Logic FPGA Each DDR controller has two DIMM slots. The first slot of each controller has up to 4 chip selects to support single-, dual- and quad-rank DIMMs. The second slot has only 2 chip selects to support single- and dual-rank DIMMs. At any given time, up to total 4 chip selects can be used. Detail information can be found in doc/README.t4qds Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
