path: root/include/configs/sunxi-common.h
2017-04-24sunxi: Fix arm64 fdtfile variableAndreas Färber
Currently $fdtfile is constructed from CONFIG_DEFAULT_TREE, containing the filename. However on arm64 that file is located in an allwinner subdirectory. To avoid the need for users/distros symlinking the .dtb files, prepend the vendor directory for ARM64. This aligns Pine64 with other boards such as Raspberry Pi 3. Signed-off-by: Andreas Färber <afaerber@suse.de> Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-21sunxi: add basic V3s supportIcenowy Zheng
Basic U-Boot support is now present for V3s. Some memory addresses are changed specially for V3s, as the original address map cannot fit into a so small DRAM. As the DRAM controller code needs a big refactor, the SPL support is disabled in this version. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Convert CONS_INDEX to KconfigMylène Josserand
Convert the CONS_INDEX configuration to Kconfig. Update sunxi's defconfigs to remove SYS_EXTRA_OPTIONS variable not needed anymore. Default value is 1 except for sun5i (equals 2) and sun8i (equals 5). Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> [Maxime: Added a depends on ARCH_SUNXI to avoid build breakages] Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-08Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2017-04-07sunxi: Add default environment sizeMaxime Ripard
On boards that defines ENV_IS_NOWHERE, such as the NES classic, commit 19dbe7d1a3f7 ("common: Move environment choice to Kconfig") broke the build because of a missing environment size. Reintroduce a default environment size consistent with what we had before. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-07sunxi: Add the default mtdids and mtdparts to our envMaxime Ripard
In order for the user to be able to see and modify them, add those variables to the default environment. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-07sunxi: Enable UBI and NAND supportHans de Goede
Enable the NAND and UBI support in the configuration header so that we can (finally) use it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Jagan Teki <jagan@openedev.com>
2017-04-07common: Move environment choice to KconfigMaxime Ripard
The environment location is something that might change per board (depending on what storage options are availaible there) or depending on the user choice (when we have several options). Instead of hardcoding it in our configuration header, create a Kconfig choice with the options we use for now, and the symbols that depend on it. Once done, also remove the irrelevant sunxi defines. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05sunxi: Kconfig: introduce CONFIG_SUNXI_HIGH_SRAMAndre Przywara
Traditionally Allwinner SoCs have their boot ROM mapped just below 4GB, while the first SRAM region is mapped at address 0. With the extended physical memory support of the A80 this was changed, so the BROM is now at address 0 and the SRAM region starts right behind this at 64KB. This configuration seems to be called "high SRAM". Instead of enumerating the SoCs which have copied this configuration, let's call a spade a spade and introduce a Kconfig option for this setup. SoCs implementing this (A80, A64 and H5, so far), can then select this configuration. Simplify the config header definition on the way. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-05sunxi: configs: merge sun9i and sun50i SPL memory definitionsAndre Przywara
For some reason we were pretty conservative when defining the maximum SPL size for the Allwinner A80(sun9i) SoC. According to the manual the SRAM A1 is even 40KB, but the BROM probably still has the 32 KiB load limit. For the sake of simplicity, merge the SPL memory definitions for the A64 and A80 SoCs, since both SoC share the BROM/SRAM A1 memory layout. This helps to further simplify this is in the next patch. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-05ARM: rename CONFIG_TIMER_CLK_FREQ to COUNTER_FREQUENCYAndre Przywara
Many ARMv8 boards define a constant COUNTER_FREQUENCY to specify the frequency of the ARM Generic Timer (aka. arch timer). ARMv7 boards traditionally used CONFIG_TIMER_CLK_FREQ for the same purpose. It seems useful to unify them. Since there are less occurences of the latter version, lets convert all users over to COUNTER_FREQUENCY. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-04sunxi: A64: enable SPLAndre Przywara
Now that the SPL is ready to be compiled in AArch64 and the DRAM init code is ready, enable SPL support for the A64 SoC and in the Pine64 defconfig. For now we keep the boot0 header in the U-Boot proper, as this allows to still use boot0 as an SPL replacement without hurting the SPL use case. We disable FEL support for now by making its compilation conditional and disabling it for ARM64, as the code isn't ready yet. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-04armv8: prevent using THUMBAndre Przywara
The predominantely 32-bit ARM targets try to compile the SPL in Thumb mode to reduce code size. The 64-bit AArch64 instruction set does not know an alternative, concise encoding, so the Thumb build option should only be set for 32-bit targets. Likewise -marm machine options are only valid for ARMv7 targets. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2016-11-28sunxi: mmc: Set CONFIG_SYS_MMC_MAX_DEVICEEmmanuel Vadot
Set CONFIG_SYS_MMC_MAX_DEVICE to 4 for sunxi SoC. This define is needed in the API code. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-30sunxi: Rename CONFIG_SUNXI to CONFIG_ARCH_SUNXIJagan Teki
CONFIG_SUNXI -> CONFIG_ARCH_SUNXI and removed CONFIG_SUNIX from config_whitelist.txt Cc: Simon Glass <sjg@chromium.org> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONFIG_CFB_CONSOLE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONSOLE_PRE_CONSOLE_BUFFER options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-06Revert "sunxi: Move the SPL stack top to 0x1A000 on Allwinner A64/A80"Andre Przywara
This commit moved the SPL stack into SRAM C, which worked when the SPL set the AHB1 clock down to 100 MHz to cope with the flaky SRAM C access from the CPU. However booting with boot0 (and thus not using SPL at all) we still run with a 200 MHz AHB1, so any access to SRAM C is prone to fail. Since this commit does _not_ only affect the SPL code, but also the U-Boot proper, we fail when booting with boot0. As the introduction of tiny-printf reduced the size of the SPL, we can afford to have the SPL stack in SRAM A1. This reverts commit 1a83fb4a17d959d7b037999ab7ed7e62429abe34 and fixes booting the Pine64 when using boot0. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-07-24sunxi: nand: Increase CONFIG_SYS_NAND_MAX_ECCPOS valueBoris Brezillon
On some sunxi boards we have NANDs exposing 1664 OOB bytes per page. Define the CONFIG_SYS_NAND_MAX_ECCPOS value accordingly. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
2016-07-24mtd: nand: Add the sunxi NAND controller driverBoris Brezillon
We already have an SPL driver for the sunxi NAND controller, now add the normal/standard one. The source has been copied from Linux 4.6 with a few changes to make it work in u-boot. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-07-15sunxi: Support booting from SPI flashSiarhei Siamashka
Allwinner devices support SPI flash as one of the possible bootable media type. The SPI flash chip needs to be connected to SPI0 pins (port C) to make this work. More information is available at: https://linux-sunxi.org/Bootable_SPI_flash This patch adds the initial support for booting from SPI flash. The existing SPI frameworks are not used in order to reduce the SPL code size. Right now the SPL size grows by ~370 bytes when CONFIG_SPL_SPI_SUNXI option is enabled. While there are no popular Allwinner devices with SPI flash at the moment, testing can be done using a SPI flash module (it can be bought for ~2$ on ebay) and jumper wires with the boards, which expose relevant pins on the expansion header. The SPI flash chips themselves are very cheap (some prices are even listed as low as 4 cents) and should not cost much if somebody decides to design a development board with an SPI flash chip soldered on the PCB. Another nice feature of the SPI flash is that it can be safely accessed in a device-independent way (since we know that the boot ROM is already probing these pins during the boot time). And if, for example, Olimex boards opted to use SPI flash instead of EEPROM, then they would have been able to have U-Boot installed in the SPI flash now and boot the rest of the system from the SATA hard drive. Hopefully we may see new interesting Allwinner based development boards in the future, now that the software support for the SPI flash is in a better shape :-) Testing can be done by enabling the CONFIG_SPL_SPI_SUNXI option in a board defconfig, then building U-Boot and finally flashing the resulting u-boot-sunxi-with-spl.bin binary over USB OTG with a help of the sunxi-fel tool: sunxi-fel spiflash-write 0 u-boot-sunxi-with-spl.bin The device needs to be switched into FEL (USB recovery) mode first. The most suitable boards for testing are Orange Pi PC and Pine64. Because these boards are cheap, have no built-in NAND/eMMC and expose SPI0 pins on the Raspberry Pi compatible expansion header. The A13-OLinuXino-Micro board also can be used. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-06-10sunxi: Move the SPL stack top to 0x1A000 on Allwinner A64/A80Siarhei Siamashka
Since the SRAM C corruption issue is now resolved on Allwinner A64, it is possible to move the stack top to the address 0x1A000 on both A64 and A80. The boot ROM can load SPL binaries with up to 32 KiB size on A64 (the 24 KiB SPL size limitation only affects A10/A20), and this patch also ensures the availability of 8 KiB stack. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-05-25arm64: sunxi: adjust default load addressesAndre Przywara
As arm64 has slightly different expectations about load addresses, lets use a different set of default addresses for things like the kernel. As arm64 kernels don't come with a decompressor right now, reserve some more space for really big uncompressed kernels. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
