path: root/include/configs/sun9i.h
2015-05-29sun9i: Basic sun9i (A80) supportHans de Goede
Add initial sun9i (A80) support, only uart + mmc are supported for now. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
