path: root/include/configs/sun8i.h
2019-01-18sunxi: usb: Switch to Generic host controllersJagan Teki
Onc of key blocker for using USB Generic host controller drivers in Allwinner are CLK and RESET drivers, now these available for USB usage. So switch sunxi USB use EHCI and OHCI Generic controllers. Enabling USB is wisely a board choise, So Enable USB_OHCI_HCD where it already have USB_EHCI_HCD Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-07-31configs: sunxi: Drop CONFIG_SUNXI_USB_PHYSJagan Teki
Now number of PHY on Allwinner is handling via dt data, drivers at phy/allwinner/phy-sun4i-usb.c Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-04-21sunxi: add basic V3s supportIcenowy Zheng
Basic U-Boot support is now present for V3s. Some memory addresses are changed specially for V3s, as the original address map cannot fit into a so small DRAM. As the DRAM controller code needs a big refactor, the SPL support is disabled in this version. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-10-30sunxi: remove unneeded CONFIG_USB_MAX_CONTROLLER_COUNT definesMasahiro Yamada
ARCH_SUNXI selects DM_USB, where CONFIG_USB_MAX_CONTROLLER_COUNT is not used. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-09-07ARM: armv7: move ARMV7_PSCI_NR_CPUS to KconfigMasahiro Yamada
Move this option to Kconfig and set its default value to 4; this increases the number of supported CPUs for some boards. It consumes 1KB memory per CPU for PSCI stack, but it should not be a big deal, given the amount of memory used for the modern OSes. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-07ARM: armv7: move CONFIG_ARMV7_PSCI to KconfigMasahiro Yamada
Add ARCH_SUPPORT_PSCI as a non-configurable option that platforms can select. Then, move CONFIG_ARMV7_PSCI, which is automatically enabled if both ARMV7_NONSEC and ARCH_SUPPORT_PSCI are enabled. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-01sunxi: Add support for Allwinner A64 SoCsSiarhei Siamashka
The Allwinner A64 SoC is used in the Pine64. This patch adds all bits necessary to compile U-Boot for it running in AArch64 mode. Unfortunately SPL is not ready yet due to legal problems, so we need to boot using the binary boot0 for now. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> [agraf: remove SPL code, move to AArch64] Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-03-31sunxi: usb_phy: Add support for A83T USB PHYsChen-Yu Tsai
The A83T has 3 USB PHYs: 1 for USB OTG, 1 for standard USB 1.1/2.0 host, 1 for USB HSIC. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-02-23sunxi: H3: Add support for the host usb-physJelle van der Waa
Add support for phy 1-3. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> [hdegoede@redhat.com: use setclrbits_le32 instead of read-modify-write] Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-12-10sunxi: Add Machine Support for A83T SOCvishnupatekar
Allwinner A83T is octa-core cortex-a7 SOC. This enables support for A83T. SMP is not yet supported. Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-11-22sunxi: Add basic H3 supportJens Kuske
Add initial sun8i H3 support, only uart + mmc are supported for now. Signed-off-by: Jens Kuske <jenskuske@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-06-28Revert "sunxi/nand: Add support to the SPL for loading u-boot from internal ↵Ian Campbell
NAND memory" This reverts commit f76eba38b3eda905ff3bdc18dd1240d3dcbc6e5a. This patch did not have a full and proper copyright/S-o-b chain. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Conflicts: include/configs/sun6i.h include/configs/sun8i.h
2015-05-29ARM: sunxi: Enable PSCI for sun8iChen-Yu Tsai
sun8i uses the same PSCI backend as sun6i, without power clamps. Since there is no secure SRAM, the backend is placed at the end of DRAM. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-29sunxi/nand: Add support to the SPL for loading u-boot from internal NAND memoryDaniel Kochmański
This commit adds support to the sunxi SPL to load u-boot from the internal NAND. Note this only adds support to access the boot partitions to load u-boot, full NAND support to load the kernel, etc. from the nand data partition will come later. Signed-off-by: Roy Spliet <r.spliet@ultimaker.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-04sunxi: usb: Do not call phy_probe from hcd codeHans de Goede
The 2/3 usb-phys on the sunxi SoCs are really a single separate functional block, and are modelled as such in devicetree. So once we've moved all the sunxi usb code to the driver-model then phy_probe will be called once for the entire block from the driver-model enumeration code. Move to this now as this also avoids problems with phy_probe being called multiple times once we introduce ohci support. This also allows us to get rid of the sunxi_usb_phy_enabled_count variable as phy_probe now is guaranteed to be called only once. Since we're effectively rewriting the probe / remove functions, move them to the end of the file while we are at it, as that is the most logical place for them. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-03-29sunxi: use CONFIG_SYS_CLK_FREQ to set cpu clockIain Paton
make the CPU clock selectable via Kconfig this removes the sunxi specific CONFIG_CLK_FULL_SPEED defined in each soc header and replaces it's use in board/sunxi/board.c with CONFIG_SYS_CLK_FREQ from Kconfig which allows us to configure board specific frequency on boot Signed-off-by: Iain Paton <ipaton0@gmail.com> [hdegoede@redhat.com s/CONFIG_SYS_CLK_FREQ/CONFIG_TIMER_CLK_FREQ/ for the arch-timer clk speed on sun7i to fix mis-compile on sun7i] Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-23sunxi: Use a common CONFIG_SYS_PROMPTIan Campbell
The CPU info is already logged during boot e.g. CPU: Allwinner A20 (SUN7I) so the prompt is just one more thing to change for each new SoC, just makes it "sunxi#" instead. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-14sunxi: Move usb-controller init code out of ehci-sunxi.c for reuse for otgHans de Goede
Most of the usb-controller init code found in ehci-sunxi.c also is necessary to init the otg usb controller, so move it to a common place. While at it also update various #ifdefs / defines for sun8i support. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun8i: Add dram initialization supportHans de Goede
Based on the register / dram_para headers from the Allwinner u-boot / linux sources + the init sequences from boot0. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-05sunxi: Use CONFIG_MACH_SUN?I from Kconfig instead of CONFIG_SUN?IIan Campbell
Mostly automatic with: sed -i -e 's/CONFIG_\(SUN[45678]I\)/CONFIG_MACH_\1/g' $(git grep -l CONFIG_SUN[45678]I) followed by removing the relevant #defines from include/configs/sun?i.h by hand. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-10-24ARM: sunxi: Add basic A23 supportChen-Yu Tsai
The basic blocks of the A23 are similar to the A31 (sun6i). Re-use sun6i code for initial clock, gpio, and uart setup. There is no SPL support for A23, as we do not have any documentation or sample code for DRAM initialization. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
