path: root/include/configs/sun7i.h
2014-11-25sun7i: Drop CONFIG_ARMV7_PSCI_NR_CPUSHans de Goede
It is not used anywhere. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-24ARM: Add arch/arm/cpu/armv7/Kconfig with non-secure and virt optionsHans de Goede
Add arch/arm/cpu/armv7/Kconfig with non-secure and virt options, this is a preparation patch for adding an env variable to choose between secure / non-secure boot on non-secure boot capable systems, specifically this prepares for adding CONFIG_ARMV7_BOOT_SEC_DEFAULT as a proper Kconfig option. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-13sunxi: ehci: Add proper Kconfig options to select the usb Vbus gpio-sHans de Goede
Add proper Kconfig options to select the usb Vbus gpio-s, besides moving to Kconfig being the right thing to do, an added advantage of this is that it allows for boards without Vbus gpio-s. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-05sunxi: Use CONFIG_MACH_SUN?I from Kconfig instead of CONFIG_SUN?IIan Campbell
Mostly automatic with: sed -i -e 's/CONFIG_\(SUN[45678]I\)/CONFIG_MACH_\1/g' $(git grep -l CONFIG_SUN[45678]I) followed by removing the relevant #defines from include/configs/sun?i.h by hand. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-10-24sunxi: Add CONFIG_MACH_TYPE defines to sun4i, sun5i and sun7iHans de Goede
Many people are still using old linux-sunxi-3.4 kernels on sunxi devices, adding the proper MACH_TYPE defines for this allows people to switch to upstream u-boot, so that we can stop maintaining the linux-sunxi u-boot fork. These machine-ids are all properly registered at: http://www.arm.linux.org.uk/developer/machines/ Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-31sunxi: HYP/non-sec: configure CNTFRQ on all CPUsMarc Zyngier
CNTFRQ needs to be properly configured on all CPUs. Otherwise, virtual machines hoping to find valuable information on secondary CPUs will be disapointed... Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-07-31sunxi: HYP/non-sec: add sun7i PSCI backendMarc Zyngier
So far, only supporting the CPU_ON method. Other functions can be added later. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-07-31sun7i: add USB EHCI settingsRoman Byshko
Specific USB EHCI settings to be set for sun7i if CONFIG_USB_EHCI is enabled. Signed-off-by: Roman Byshko <rbyshko@gmail.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> [hdegoede@redhat.com: Use SUNXI_GPH macro for SUNXI_USB_VBUS#_GPIO] [hdegoede@redhat.com: Add #ifndef SUNXI_USB_VBUS#_GPIO to allow override of the default pins from boards.cfg] Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-07-18sunxi: Add axp209 pmic supportHenrik Nordstrom
Add support for the x-powers axp209 pmic which is found on most A10, A13 and A20 boards. And enable AXP209 support for the Cubietruck and Cubieboard boards. Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-05-25sunxi: add sun7i cpu, board and start of day supportIan Campbell
This patch adds generic board, start of day and basic build system support for the Allwinner A20 (sun7i) processor. This code will not been compiled until the build is hooked up in a later patch. It has been split out to keep the patches manageable. Signed-off-by: Adam Sampson <ats@offog.org> Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com> Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com> Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Emilio López <emilio@elopez.com.ar> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Luc Verhaegen <libv@skynet.be> Signed-off-by: Luke Leighton <lkcl@lkcl.net> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Patrick Wood <patrickhwood@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Wills Wang <wills.wang.open@gmail.com> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Marek Vasut <marex@denx.de> Cc: Tom Cubie <Mr.hipboi@gmail.com> Reviewed-by: Tom Rini <trini@ti.com>
