path: root/include/configs/sun6i.h
2018-07-31configs: sunxi: Drop CONFIG_SUNXI_USB_PHYSJagan Teki
Now number of PHY on Allwinner is handling via dt data, drivers at phy/allwinner/phy-sun4i-usb.c Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-10-30sunxi: remove unneeded CONFIG_USB_MAX_CONTROLLER_COUNT definesMasahiro Yamada
ARCH_SUNXI selects DM_USB, where CONFIG_USB_MAX_CONTROLLER_COUNT is not used. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-09-07ARM: armv7: move ARMV7_PSCI_NR_CPUS to KconfigMasahiro Yamada
Move this option to Kconfig and set its default value to 4; this increases the number of supported CPUs for some boards. It consumes 1KB memory per CPU for PSCI stack, but it should not be a big deal, given the amount of memory used for the modern OSes. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-07ARM: armv7: move CONFIG_ARMV7_PSCI to KconfigMasahiro Yamada
Add ARCH_SUPPORT_PSCI as a non-configurable option that platforms can select. Then, move CONFIG_ARMV7_PSCI, which is automatically enabled if both ARMV7_NONSEC and ARCH_SUPPORT_PSCI are enabled. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-07-15sunxi: Define CONFIG_ARMV7_SECURE_MAX_SIZE for sun6i/sun7iChen-Yu Tsai
Both sun6i and sun7i have 64 KB of secure SRAM. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-01sunxi: Add support for Allwinner A64 SoCsSiarhei Siamashka
The Allwinner A64 SoC is used in the Pine64. This patch adds all bits necessary to compile U-Boot for it running in AArch64 mode. Unfortunately SPL is not ready yet due to legal problems, so we need to boot using the binary boot0 for now. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> [agraf: remove SPL code, move to AArch64] Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-06-28Revert "sunxi/nand: Add support to the SPL for loading u-boot from internal ↵Ian Campbell
NAND memory" This reverts commit f76eba38b3eda905ff3bdc18dd1240d3dcbc6e5a. This patch did not have a full and proper copyright/S-o-b chain. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Conflicts: include/configs/sun6i.h include/configs/sun8i.h
2015-05-29ARM: sunxi: Enable PSCI for sun6iChen-Yu Tsai
Now that we have a PSCI backend for sun6i, enable it. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-29sunxi/nand: Add support to the SPL for loading u-boot from internal NAND memoryDaniel Kochmański
This commit adds support to the sunxi SPL to load u-boot from the internal NAND. Note this only adds support to access the boot partitions to load u-boot, full NAND support to load the kernel, etc. from the nand data partition will come later. Signed-off-by: Roy Spliet <r.spliet@ultimaker.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-04sunxi: usb: Do not call phy_probe from hcd codeHans de Goede
The 2/3 usb-phys on the sunxi SoCs are really a single separate functional block, and are modelled as such in devicetree. So once we've moved all the sunxi usb code to the driver-model then phy_probe will be called once for the entire block from the driver-model enumeration code. Move to this now as this also avoids problems with phy_probe being called multiple times once we introduce ohci support. This also allows us to get rid of the sunxi_usb_phy_enabled_count variable as phy_probe now is guaranteed to be called only once. Since we're effectively rewriting the probe / remove functions, move them to the end of the file while we are at it, as that is the most logical place for them. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-03-29sunxi: use CONFIG_SYS_CLK_FREQ to set cpu clockIain Paton
make the CPU clock selectable via Kconfig this removes the sunxi specific CONFIG_CLK_FULL_SPEED defined in each soc header and replaces it's use in board/sunxi/board.c with CONFIG_SYS_CLK_FREQ from Kconfig which allows us to configure board specific frequency on boot Signed-off-by: Iain Paton <ipaton0@gmail.com> [hdegoede@redhat.com s/CONFIG_SYS_CLK_FREQ/CONFIG_TIMER_CLK_FREQ/ for the arch-timer clk speed on sun7i to fix mis-compile on sun7i] Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-23sunxi: Use a common CONFIG_SYS_PROMPTIan Campbell
The CPU info is already logged during boot e.g. CPU: Allwinner A20 (SUN7I) so the prompt is just one more thing to change for each new SoC, just makes it "sunxi#" instead. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-13sun6i: ehci: Add sun6i ehci supportHans de Goede
Add support for the 2 ehci controllers found on the sun6i (A31) soc. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Marek Vasut <marex@denx.de>
2014-11-13sun6i: Add clock functions needed for SPL / DRAM initHans de Goede
Add clock_init_safe and clockset_pll5 functions, as these are needed for SPL support resp. DRAM init (which is needed for SPL too). Also add some extra clock register constant defines. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-05sunxi: Use CONFIG_MACH_SUN?I from Kconfig instead of CONFIG_SUN?IIan Campbell
Mostly automatic with: sed -i -e 's/CONFIG_\(SUN[45678]I\)/CONFIG_MACH_\1/g' $(git grep -l CONFIG_SUN[45678]I) followed by removing the relevant #defines from include/configs/sun?i.h by hand. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-10-24ARM: sunxi: Add basic A31 supportMaxime Ripard
Add a new sun6i machine that supports UART and MMC. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> [wens@csie.org: use SPDX labels, adapt to Kconfig system, drop ifdef around mmc and smp code, drop MACH_TYPE] Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
