path: root/include/configs/sun4i.h
2015-06-28Revert "sunxi/nand: Add support to the SPL for loading u-boot from internal ↵Ian Campbell
NAND memory" This reverts commit f76eba38b3eda905ff3bdc18dd1240d3dcbc6e5a. This patch did not have a full and proper copyright/S-o-b chain. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Conflicts: include/configs/sun6i.h include/configs/sun8i.h
2015-05-29sunxi/nand: Add support to the SPL for loading u-boot from internal NAND memoryDaniel Kochmański
This commit adds support to the sunxi SPL to load u-boot from the internal NAND. Note this only adds support to access the boot partitions to load u-boot, full NAND support to load the kernel, etc. from the nand data partition will come later. Signed-off-by: Roy Spliet <r.spliet@ultimaker.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-04sunxi: usb: Do not call phy_probe from hcd codeHans de Goede
The 2/3 usb-phys on the sunxi SoCs are really a single separate functional block, and are modelled as such in devicetree. So once we've moved all the sunxi usb code to the driver-model then phy_probe will be called once for the entire block from the driver-model enumeration code. Move to this now as this also avoids problems with phy_probe being called multiple times once we introduce ohci support. This also allows us to get rid of the sunxi_usb_phy_enabled_count variable as phy_probe now is guaranteed to be called only once. Since we're effectively rewriting the probe / remove functions, move them to the end of the file while we are at it, as that is the most logical place for them. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-03-29sunxi: use CONFIG_SYS_CLK_FREQ to set cpu clockIain Paton
make the CPU clock selectable via Kconfig this removes the sunxi specific CONFIG_CLK_FULL_SPEED defined in each soc header and replaces it's use in board/sunxi/board.c with CONFIG_SYS_CLK_FREQ from Kconfig which allows us to configure board specific frequency on boot Signed-off-by: Iain Paton <ipaton0@gmail.com> [hdegoede@redhat.com s/CONFIG_SYS_CLK_FREQ/CONFIG_TIMER_CLK_FREQ/ for the arch-timer clk speed on sun7i to fix mis-compile on sun7i] Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-21sunxi: Machine id hack to prevent loading buggy sunxi-3.4 kernelsSiarhei Siamashka
Right now U-Boot supports the CONFIG_OLD_SUNXI_KERNEL_COMPAT option, which makes it go out of its way in limiting the selection of PLL clock frequencies and PMIC voltages in order not to upset outdated buggy sunxi-3.4 kernel releases. And if the CONFIG_OLD_SUNXI_KERNEL_COMPAT option is not set, then booting such old kernels exhibits various failures at runtime. This is very user unfriendly, and there were already several incidents when people wasted their time being hit by these runtime failures and trying to debug them. The right solution is not to add hacks and workarounds to the mainline U-Boot, but to fix these bugs in the sunxi-3.4 kernel. And in fact, the updated sunxi-3.4 kernels already exist. Still we need to follow the 'Principle of Least Surprise' and U-Boot needs to ensure that the old buggy kernels are not getting happily booted when the CONFIG_OLD_SUNXI_KERNEL_COMPAT option is not set. And this patch addresses this particular issue. This patch makes U-Boot store the 'compatibility revision' number in the top 4 bits of the machine id and pass it to the kernel. The old buggy kernels will fail to load with a very much googlable error message on the serial console (the "r1 = 0x100010bb" part of it): "Error: unrecognized/unsupported machine ID (r1 = 0x100010bb)" This error message can be documented in the linux-sunxi wiki with proper explanations about how to resolve this situation and where to get the necessary bugfixes for the sunxi-3.4 kernel. The fixed sunxi-3.4 kernels implement a revision compatibility check and clear the top 4 bits of the machine id if everything is alright. By accepting the machine id with the bits 31:28 set to 1, the sunxi-3.4 kernel effectively certifies that it has the PLL5 clock speed and AXP209 DCDC3 voltage fixes applied. It is still possible to set the CONFIG_OLD_SUNXI_KERNEL_COMPAT option in U-Boot if the user desires to use an outdated unpatched sunxi-3.4 kernel. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-23sunxi: Use a common CONFIG_SYS_PROMPTIan Campbell
The CPU info is already logged during boot e.g. CPU: Allwinner A20 (SUN7I) so the prompt is just one more thing to change for each new SoC, just makes it "sunxi#" instead. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-13sunxi: ehci: Add proper Kconfig options to select the usb Vbus gpio-sHans de Goede
Add proper Kconfig options to select the usb Vbus gpio-s, besides moving to Kconfig being the right thing to do, an added advantage of this is that it allows for boards without Vbus gpio-s. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-05sunxi: Use CONFIG_MACH_SUN?I from Kconfig instead of CONFIG_SUN?IIan Campbell
Mostly automatic with: sed -i -e 's/CONFIG_\(SUN[45678]I\)/CONFIG_MACH_\1/g' $(git grep -l CONFIG_SUN[45678]I) followed by removing the relevant #defines from include/configs/sun?i.h by hand. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-10-24sunxi: Add CONFIG_MACH_TYPE defines to sun4i, sun5i and sun7iHans de Goede
Many people are still using old linux-sunxi-3.4 kernels on sunxi devices, adding the proper MACH_TYPE defines for this allows people to switch to upstream u-boot, so that we can stop maintaining the linux-sunxi u-boot fork. These machine-ids are all properly registered at: http://www.arm.linux.org.uk/developer/machines/ Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-31sun4i: add USB EHCI settingsHans de Goede
Specific USB EHCI settings to be set for sun4i if CONFIG_USB_EHCI is enabled. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-18sunxi: Add axp209 pmic supportHenrik Nordstrom
Add support for the x-powers axp209 pmic which is found on most A10, A13 and A20 boards. And enable AXP209 support for the Cubietruck and Cubieboard boards. Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-06sunxi: Add sun4i supportHans de Goede
Add support for the Allwinner A10 SoC also known as the Allwinner sun4i family, and add the Cubieboard board which uses the A10 SoC. Compared to sun7 only the DRAM controller is a bit different: -Controller reset bits are inverted, but only for Rev. A -Different hpcr values -No MBUS on sun4i -Various other initialization changes Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
