path: root/include/configs/suen8.h
2011-05-31arm/km: move CONFIG_EXTRA_ENV_SETTINGS from board to km_arm fileValentin Longchamp
Since all the boards define the same env settings, this simplifies the board files. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-05-10keymile boards: move keymile specific header in subdirValentin Longchamp
Collect all keymile specific common headers in include/configs/km. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Holger Brunck <holger.brunck@keymile.com>
2011-04-30arm, keymile: updates for the arm based boards from keymileHeiko Schocher
define KM_IVM_BUS and KM_ENV_BUS macros KM_IVM_BUS is used to define the EEprom_ivm environment variable. These macros allow the reuse of these I2C addresses in other code locations. remove unneeded code On first HW versions the BOCO FPGA was behind a MUX device. These HW versions are not supported anymore. And therefore this code can be removed. added LED initialization for SUEN3 The bootstat LED required to be initialized so to have a green colour after start-up. define CONFIG_SYS_TEXT_BASE This is needed by the relocation code and is not the same for our ARM BEC and thus needs to be defined. remove memsize variable An environment variable for memsize is not needed. this can be get via the board info struct. remove unneeded double access to bi_dram[i].size field Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Luca Haab <luca.haab@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30arm: add support of Kirkwood based board SUEN8Heiko Schocher
The Kirwood based SUEN8 board from Keymile is at this stage the same than the suen3 board. This patch adds the board support for the suen8. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
