path: root/include/configs/stxxtc.h
2009-09-22FDT: remove obsolete OF_CPU and OF_SOC macros.Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@noser.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Heiko Schocher <hs@denx.de>
2009-07-17Remove legacy NAND and disk on chip references from boards.Scott Wood
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-09-09stxxtc: remove empty CONFIG_SHOW_ACTIVITY functionsWolfgang Denk
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-06-09Change the stxxst to CONFIG_OF_LIBFDTGerald Van Baren
This was configured to use the deprecated CONFIG_OF_FLAT_TREE, change to CONFIG_OF_LIBFDT. WARNING: It appears that this board lost its ability to boot via a flattened device tree prior to this changeset. WARNING: This conversion was untested because I do not have a board to test it on. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2008-04-13Add CONFIG_MII_INIT support to related boardsTsiChung Liew
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in cmd_init.c. Add CONFIG_MII_INIT to board configuration files that use mii_init() in cmd_init.c. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-26Remove deprecated CONFIG_OF_HAS_UBOOT_ENV and CONFIG_OF_HAS_BD_TJerry Van Baren
These defines embedded the u-boot env variables and/or the bd_t structure in the fdt blob. The conclusion of discussion on the u-boot email list was that embedding these in the fdt blob is not useful: there are better ways of passing the data (in fact, the fdt blob itself replaces the bd_t struct). The only board that enables these is the stxxtc and they don't appear to be used by linux. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-07-09include/configs/[m-z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in STx board config files.Jon Loeliger
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-01-11Added CONFIG_ options for bd_t and env in flat dev treeKumar Gala
CONFIG_OF_HAS_BD_T will put a copy of the bd_t into the resulting flat device tree. CONFIG_OF_HAS_UBOOT_ENV will copy the environment variables from u-boot into the flat device tree Patch by Kumar Gala 11 Jan 2006
2005-10-13Add support for OF flat tree for the STXtc board.Wolfgang Denk
Patch by Pantelis Antoniou, 04 Sep 2005
2005-09-13Change default console baud rate for stxxtc boardWolfgang Denk
2005-08-15Add support for Silicon Turnkey eXpress XTc (mpc87x/88x) board.Wolfgang Denk
Patch by Dan Malek and Pantelis Antoniou, 15 Aug 2005
