path: root/include/configs/stxssa.h
2008-06-11FSL LAW: Keep track of LAW allocationsKumar Gala
Make it so we keep track of which LAWs have allocated and provide a function (set_next_law) which can allocate a LAW for us if one is free. In the future we will move to doing more "dynamic" LAW allocation since the majority of users dont really care about what LAW number they are at. Also, add CONFIG_MPC8540 or CONFIG_MPC8560 to those boards which needed them Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Get ride of old TLB setup codeKumar Gala
Now that all boards have been converted, remove old config code and the config option for the new style. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Convert STXGP3 & STXSSA to new TLB setupKumar Gala
2008-01-1685xx: convert STXGP3/STXSSA over to use new LAW init codeKumar Gala
2008-01-0985xx: Remove cache config from configs.hKumar Gala
Either use the standard defines in asm/cache.h or grab the information at runtime from the L1CFG SPR. Also, minor cleanup in cache.h to make the code a bit more readable. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-12GP3 SSA: enable RTCWolfgang Denk
2007-09-11[GP3SSA] Add define CONFIG_MPC85XX_PCI2 in config file to allow u-boot toGrzegorz Bernacki
scan on second pci bus. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2007-08-16Add CONFIG_HAS_ETH0 to all boards with TSECAndy Fleming
The 85xx code now relies on CONFIG_HAS_ETH0 to determine whether to update TSEC1's device-tree node, so we need to add it to all the boards with TSECs. Do this for 83xx and 86xx, too, since they will eventually do something similar. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-16Define tsec flag values in config filesAndy Fleming
The tsec_info structure and array has a "flags" field for each ethernet controller. This field is the only reason there are settings. Switch to defining TSECn_FLAGS for each controller in the config header, and we can greatly simplify the array, and also simplify the addition of future boards. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-06Code cleanup and default config update for STC GP3 SSA board.Wolfgang Denk
2007-07-05include/configs: Use new CONFIG_CMD_* in STx board config files.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in 85xx board config files.Jon Loeliger
2007-07-03Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-05-31Add support for STX GP3SSA (stxssa) Board with 4 MiB flash.Wolfgang Denk
2007-05-17Reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECxKim Phillips
For all practical u-boot purposes, TSECs don't differ throughout the mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-05-03Update board configuration for STX GP3SSA board:Wolfgang Denk
Enable hush shell, environment in flash rather in EEPROM, more user-friendly default environment, etc. The simple EEPROM environment can be selected easily in the board config file. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-05-03Add support for STX GP3SSA (stxssa) BoardDan Malek
Signed-off-by Dan Malek, <dan@embeddedalley.com>
