path: root/include/configs/stv0991.h
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-09ARM: Drop unreferenced CONFIG_* defines named after SoCsTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_ARM926EJS CONFIG_CPUAT91 CONFIG_EXYNOS5800 CONFIG_SYS_CORTEX_R4 Most of them are config symbols named after the respective SoCs which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-01-28pl01x: Convert CONFIG_PL01X_SERIAL to KconfigAlexander Graf
We want to use Kconfig logic to depend on whether pl01x devices are built in, so let's convert their inclusion selection to Kconfig. This round goes to pl01x. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-24Revert "spi: cadence_qspi_apb: Use 32 bit indirect write transaction when ↵Vignesh R
possible" This reverts commit 57897c13de03ac0136d64641a3eab526c6810387. Using bounce_buf.c to handle non-DMA alignment problems is bad as bounce_buf.c does cache manipulations which is not required. Therefore revert this patch in favour of local bounce buffer solution in the next patch. Signed-off-by: Vignesh R <vigneshr@ti.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Reviewed-by: Jason Rush <jarush@gmail.com> Acked-by: Jason Rush <jarush@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-01-24config: cadence_spi: Remove defines read from DTJason Rush
Cleanup unused #define values that are read from the DT. Tested on TI K2G platform: Tested-by: Vignesh R <vigneshr@ti.com> Tested on a socfpga-cyclonev board: Tested-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Signed-off-by: Jason Rush <jarush@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Acked-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Acked-by: Marek Vasut <marex@denx.de>
2017-11-06stv0991: fix STMicroelectronics copyrightPatrice Chotard
Uniformize STMicroelectronics copyrights headers for STV0991 related code. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-01-04spi: cadence_qspi_apb: Use 32 bit indirect write transaction when possibleVignesh R
According to Section 11.15.4.9.2 Indirect Write Controller of K2G SoC TRM SPRUHY8D[1], the external master is only permitted to issue 32-bit data interface writes until the last word of an indirect transfer otherwise indirect writes is known to fails sometimes. So, make sure that QSPI indirect writes are 32 bit sized except for the last write. If the txbuf is unaligned then use bounce buffer to avoid data aborts. So, now that the driver uses bounce_buffer, enable CONFIG_BOUNCE_BUFFER for all boards that use Cadence QSPI driver. [1]www.ti.com/lit/ug/spruhy8d/spruhy8d.pdf Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Jagan Teki <jagan@openedev.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-12-22net: eth_designware: select PHYLIB in KconfigThomas Chou
Select PHYLIB in drivers/net/Kconfig. And remove CONFIG_PHYLIB from legacy board header files. This fixed the warnings when both ALTERA_TSE and ETH_DESIGNWARE are selected. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reported-by: Pavel Machek <pavel@denx.de> Acked-by: Chin Liang See <clsee@altera.com> Acked-by: Pavel Machek <pavel@denx.de> Tested-by: Pavel Machek <pavel@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-03stv0991: enable cadence qspi controller & spi flashVikas Manocha
This patch does all the board configurations required to use the qspi controller & attached spi flash memory. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-07-03stv0991: remove define CONFIG_OF_SEPARATE from board fileVikas Manocha
CONFIG_OF_SEPARATE is default define with CONFIG_OF_CONTROL, removing this define from the board file to avoid multiple definition warning. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-07-03stv0991: move OF_CONTROL config to defconfigVikas Manocha
2015-07-03stv0991: enable saving enrironment in spi flashVikas Manocha
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-10stv0991: fdt: add stv0991 device treeVikas Manocha
This patch adds device tree for the ST Micro stv0991 board & enables device tree control. Progressively device tree support for the drivers being used will also be added. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-02-13dm: stv0991: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-09dm: stv0991: Move serial to driver modelVikas Manocha
2014-12-09stv0991: increase the initial ram size configVikas Manocha
It is done to make space available for driver model memory. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2014-12-09stv0991: enable default and misc command configsVikas Manocha
2014-12-09stv0991: enable ethernet supportVikas Manocha
2014-12-09stv0991: Add basic stv0991 architecture supportVikas Manocha
stv0991 architecture support added. It contains the support for following blocks - Timer - uart Signed-off-by: Vikas Manocha <vikas.manocha@st.com> [trini: Add arch/arm/cpu/armv7/Makefile hunk] Signed-off-by: Tom Rini <trini@ti.com>
