path: root/include/configs/strider.h
2018-03-09treewide: Fix gdsys mail addressesMario Six
The @gdsys.cc addresses are supposed to be used for mailing lists. Switch all occurrences of @gdsys.de mail addresses to their @gdsys.cc equivalent. Also, Dirk's address was wrong in one place; fix that as well. Signed-off-by: Mario Six <six@gdsys.cc>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-11Kconfig: Drop CONFIG_CMD_PCA953X_INFOSimon Glass
It does not seem worth having an option to enable another sub-command in this legacy driver. Drop this option so that the sub-command is always available. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_PCA953X to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_PCA953X Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-05-22Convert CONFIG_CMD_IOLOOP to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IOLOOP Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_FPGAD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FPGAD Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-04mmc: move CONFIG_SYS_FSL_ERRATUM_ESDHC* to KconfigYork Sun
Add option SYS_FSL_ERRATUM_ESDHC111, SYS_FSL_ERRATUM_ESDHC13, SYS_FSL_ERRATUM_ESDHC135, SYS_FSL_ERRATUM_ESDHC_A001 to mmc Kconfig. Move existing macros to related Kconfig. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate bk4r1] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-01autoboot: remove CONFIG_ZERO_BOOTDELAY_CHECKMasahiro Yamada
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2 means the autoboot with no delay, with no abort check even if CONFIG_ZERO_BOOTDELAY_CHECK is defined. To sum up, the autoboot behaves as follows: [1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n autoboot with no delay, with no check for abort [3] CONFIG_BOOTDELAY=-1 disable autoboot [4] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort As you notice, [2] and [4] come to the same result, which means we do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the cases only by CONFIG_BOOTDELAY, like this: [1] CONFIG_BOOTDELAY=0 autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=-1 disable autoboot [3] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort This commit converts the logic as follow: CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n --> CONFIG_BOOTDELAY=-2 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Christian Riesch <christian.riesch@omicronenergy.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2016-06-06strider: Support cpu-dp flavorDirk Eibach
There is new strider cpu flavor with DisplayPort video. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-06strider: Support con-dp flavorDirk Eibach
There is a new strider console flavor with DisplayPort video. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-21strider: use optimised bus timing for FPGA accessReinhard Pfau
Use optimised bus timing for FPGA access. Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2016-03-21strider: Define pca593x widthsDirk Eibach
2015-11-12mpc83xx: Add strider boardDirk Eibach
The gdsys strider board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card. On board peripherals include: - 1x 10/100 Mbit/s Ethernet (optional) - Lattice ECP3 FPGA connected via eLBC Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> [trini: Drop setting CONFIG_SYS_GENERIC_BOARD, this is always true now] Signed-off-by: Tom Rini <trini@konsulko.com>
