path: root/include/configs/stmark2.h
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-11-27spi: Zap CONFIG_HARD_SPIJagan Teki
In legacy CONFIG_HARD_SPI initalizing spi_init code, which was removed during dm conversion cleanup. So remove the dead instances of CONFIG_HARD_SPI, and related code. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-08-06spi: Kconfig: Create ISSI Kconfig entryMichal Simek
Add ISSI to Kconfig to make it selectable via menuconfig. Also convert all current platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-08treewide: Convert CONFIG_HOSTNAME to a string optionMario Six
CONFIG_HOSTNAME is defined as a "plain" preprocessor string, but every use is couched by __stringify(...). Hence, convert it to a proper string option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-02-13spi: Migrate CONFIG_CF_SPI to KconfigTuomas Tynkkynen
2018-01-19m68k: Drop unreferenced CONFIG_* definesTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_AMCORE CONFIG_ASTRO5373L CONFIG_M52277EVB CONFIG_M5253DEMO CONFIG_M5253EVBE CONFIG_M5275EVB CONFIG_M54418TWR CONFIG_STMARK2 Most of them are config symbols named after the respective boards which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-08-18m68k: add board stmark2, mcf5441x basedAngelo Dureghello
Sysam stmark2 board is a generic and fully (hw and sw) open board, with a mcf54415 Coldfire CPU, 128MB of DDR2, 16MB of SPI flash and SD card as non volatile memories, and a wifi module included on-board. The board is actually used mainly for Coldfire custodian testing activity related to the mcf5441x Coldfire family. For further information please see: http://sysam.it/cff_stmark2.html Signed-off-by: Angelo Dureghello <angelo@sysam.it> --- Changes in v2: - remove CMD_REGINFO - add board information in commit message
