Today the bootcount is not managed by the Linux kernel for STM32MP15 as
we don't have driver to update the used backup register in TAMP and the
recovery command still executes the normal bootcmd with
'altbootcmd=run bootcmd'.
So the bootcount feature is never used, the config CONFIG_BOOTCOUNT_LIMIT
and the associated environment variable 'altbootcmd' can be removed to
reduce the U-Boot size.
Each boards can re-enable this feature later in their defconfig, if it is
needed, with the expected backend, for example CONFIG_BOOTCOUNT_GENERIC
or CONFIG_BOOTCOUNT_ENV.
CC: Marek Vasut <marex@denx.de>
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
CONFIG_BOOTP_SERVERIP
The USB hub on STM32MP1 DHCOM boards needs to wait a bit longer until
the USB Vbus is stable. Increase the USB power-good delay to 1 s.
This adds default-undefined STM32MP_BOARD_EXTRA_ENV variable into
stm32mp15_common.h to reduce duplication in board-specific config
files adding custom environment.
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Patrick Delaunay <patrick.delaunay@foss.st.com>
In some part of STM32MP15 support the CONFIG_TFABOOT can be replaced
by other config: CONFIG_ARMV7_PSCI and CONFIG_ARM_SMCCC.
This patch also simplifies the code in cpu.c, stm32mp1_ram.c and
clk_stml32mp1.c as execution of U-Boot in sysram (boot without SPL and
without TFA) is not supported: the associated initialization code is
present only in SPL.
This cleanup patch is a preliminary step to support SPL load of OP-TEE
in secure world, with SPL in secure world and U-Boot in no-secure world.
Reported-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
Add a configuration file "stm32mp15_st_common.h" to handle the
STMicroelectronics boards configuration and rename stm32mp1.h to
"stm32mp15_common.h" to handle the generic STM32MP15x series configuration.
The configuration file "dh_stm32mp1.h" is also renamed to
"stm32mp15_dh_dhcom" for the configuration of board based on the
dhelectronics STM32MP15x SOM.
In the STMicroelectronics board configuration the default bootcmd
"bootcmd_stm32mp" is updated to only select the extlinux file found on
SD-Card on STM32MP15x EV1 for boot from NOR device.
