path: root/include/configs/stm32f746-disco.h
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-02-13board: stm32: remove fdt_high and fdt_highinitrd_highPatrice Chotard
For stm32 f4, f7 and h7 boards, remove fdt_high and initrd_high as they shouldn't be used, this allows the fdt and initrd relocation. This implies to set CONFIG_SYS_BOOTMAPSZ to indicate the amount of memory available to contain kernel, device tree and initrd for relocation. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Patrick DELAUNAY <patrick.delaunay@st.com>
2020-02-13board: stm32: fix extra env setings addressesPatrice Chotard
For stm32f4, f7 and h7 boards, reserve: - 4MB for kernel - 64KB for fdt, boot script, pxefile - the remaining memory for ramdisk Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Patrick DELAUNAY <patrick.delaunay@st.com>
2019-10-22configs: stm32f746-disco: Fix ramdisk_addr_rPatrice Chotard
Set ramdisk_addr_r to 0xC0600000. Reported-by: Christophe Priouzeau <christophe.priouzeau@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-04-23configs: stm32f746-disco: update EXTRA_ENV_SETTINGSPatrice Chotard
Allows to boot linux distribution. As stm32f746-disco and stm32f769-disco are sharing the same defconfig file, in case of stm32f769-disco build, "fdtfile=..." must be updated with the correct stm32f769 DTB file name. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13configs: stm32f746-disco: Migrate CONFIG_CMD_CACHE to defconfigPatrice Chotard
Remove CONFIG_CMD_CACHE from include/configs/stm32f746-disco.h and enable it in stm32f746-disco_defconfig Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13configs: stm32fxxx: Remove CONFIG_SYS_CLK_FREQPatrice Chotard
Since commit aa5e3e22f4d6 ("board: stm32: switch to DM STM32 timer") SYS_CLK_FREQ is useless, remove it from stm32f4 and stm32f7 boards. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-19stm32f7: board: add splash screenyannick fertre
Support several pixel format (8bits, 16bits, 24bits & 32bits). Add new file st_logo_data.h which contains logo stmicroelectronics_uboot_logo_8bit_rle.bmp. Signed-off-by: yannick fertre <yannick.fertre@st.com>
2018-02-08configs: stm32: Enable CONFIG_ENV_VARS_UBOOT_CONFIGPatrice Chotard
Enable CONFIG_ENV_VARS_UBOOT_CONFIG for all STM32 boards It allows to retrieve the SoC name into the "soc" environment variable. Signed-off-by: Christophe Priouzeau <christophe.priouzeau@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2018-01-29board: stm32: Fix stm32f746-disco bootPatrice Chotard
Since 'commit af2f44267 ("fdc spl: use different BOARD_INIT MACRO for spl and tpl")' board stm32f746-disco can't boot. The macro CONFIG_IS_ENABLED() can't evaluate the value of CONFIG_SPL_BOARD_INIT as it was defined in include/configs/stm32f746-disco.h without attributed value. Moving CONFIG_SPL_BOARD_INIT from stm32f746-disco.h to mach-stm32/Kconfig fixes this issue. Fixes: af2f44267 ("fdc spl: use different BOARD_INIT MACRO for spl and tpl") Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-28configs: stm32f: Remove STM32_HSE_HZ for all STM32F seriesPatrice Chotard
As clk_stm32f driver is able to retrieve HSE frequency from DT, CONFIG_STM32_HSE_HZ becomes useless. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-11-06stm32: fix STMicroelectronics copyrightPatrice Chotard
Uniformize STMicroelectronics copyrights headers for STM32 related code. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-31serial: stm32x7: Convert CONFIG_STM32X7_SERIAL to KconfigPatrice Chotard
Add CONFIG_STM32X7_SERIAL as a Kconfig option. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2017-06-09spl: stm32f7: configure for xip bootingVikas Manocha
With xip booting configuration, we don't need to copy the next image (U-Boot or linux xipimage) from flash to sdram area. Flash memory organization is like this: spl-U-Boot: u-boot-spl.bin : 0x0800_0000 U-Boot : u-boot-dtb.bin : 0x0800_8000 linux : xipImage : 0x0800_8000 It is also possible to have U-Boot binary & linux binaries configured at different addresses of flash memory like U-Boot at 0x0800_8000 & linux xipImage at 0x0800_4000. But in any case, spl-U-Boot needs to be compiled for U-Boot as next binary with SPL_OS_BOOT option disabled. By default, spl is configured to boot linux xipImage. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2017-06-09spl: stm32f7: add kernel boot supportVikas Manocha
2017-06-09stm32: stm32f7: add spl build supportVikas Manocha
This commit supports booting from stm32 internal nor flash. spl U-Boot initializes the sdram memory, copies next image (e.g. standard U-Boot) to sdram & then jumps to entry point. Here are the flash memory addresses for U-Boot-spl & standard U-Boot: - spl U-Boot : 0x0800_0000 - standard U-Boot : 0x0800_8000 To compile u-boot without spl: Remove SUPPORT_SPL configuration (arch/arm/mach-stm32/Kconfig) Signed-off-by: Vikas Manocha <vikas.manocha@st.com> [trini: Rework Kconfig logic a bit] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-08stm32f7: remove not needed configuration from board configVikas Manocha
This patch removes: - CONFIG_CMD_MEM: enabled by default - CONFIG_DESIGNWARE_ETH : not being used anywhere. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-05-08stm32f7: sdram: correct sdram configuration as per micron sdramVikas Manocha
Actually the sdram memory on stm32f746 discovery board is micron part MT48LC_4M32_B2B5_6A. This patch does the modification required in the device tree node & driver for the same. Also we are passing here all the timing parameters in terms of clock cycles, so no need to convert time(ns or ms) to cycles. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-05-08stm32f7: enable board info read from device treeVikas Manocha
2017-05-08stm32f7: stm32f746-disco: read memory info from device treeVikas Manocha
2017-05-08stm32f746: to switch on user LED1 & read user buttonVikas Manocha
All discovery boards have one user button & one user LED. Here we are just reading the button status & switching ON the user LED. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-05-08stm32f7: use stm32f7 gpio driver supporting driver modelVikas Manocha
With this gpio driver supporting DM, there is no need to enable clocks for different gpios (for pin muxing) in the board specific code. Need to increase the allocatable area required before relocation from 0x400 to 0xC00 becuase of 10 new gpio devices(& new gpio class) added in device tree. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-08stm32f7: enable instruction & data cacheVikas Manocha
It also enables commands for cache enable/disable/status. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2017-01-28ARM: stm32: enable support for smsc phy on stm32f746-disco boardMichael Kurz
This patch enables support for the smsc phy on the stm32f746-disco board. Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Acked-by: Vikas MANOCHA <vikas.manocha@st.com> Series-changes 3: - Add Acked-by tag to 'enable support for smsc phy on...'
2017-01-28net: stm32: add designware mac glue code for stm32Michael Kurz
This patch adds glue code required for enabling the designware mac on stm32f7 devices. Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-07-14stm32: Add SDRAM support for stm32f746 discovery boardToshifumi NISHINAGA
This patch adds SDRAM support for stm32f746 discovery board. This patch depends on previous patch. This patch is based on STM32F4 and emcraft's[1]. [1]: https://github.com/EmcraftSystems/u-boot Signed-off-by: Toshifumi NISHINAGA <tnishinaga.dev@gmail.com>
2016-07-14stm32: clk: Add 200MHz clock configuration for stm32f746 discovery boardToshifumi NISHINAGA
This patch adds 200MHz clock configuration for stm32f746 discovery board. This patch is based on STM32F4 and emcraft's[1]. [1]: https://github.com/EmcraftSystems/u-boot Signed-off-by: Toshifumi NISHINAGA <tnishinaga.dev@gmail.com>
2016-04-18kconfig: Move CONFIG_OF_LIBFDT to KconfigMichal Simek
This patch follows work done by: "Move CONFIG_OF_LIBFDT to Kconfig" (sha1: 69e173eb57d1f4848f070c83456096ba5d2ba1b4) Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Add xpress* to the patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-26stm32f746-disco: enable flash supportVikas Manocha
This patch enables embedded flash for stm32f746 discovery board. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2016-02-24stm32: add support for stm32f7 & stm32f746 discovery boardVikas Manocha
This patch adds support for stm32f7 family & stm32f746 board. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
