path: root/include/configs/stm32f746-disco.h
2017-05-08stm32f7: remove not needed configuration from board configVikas Manocha
This patch removes: - CONFIG_CMD_MEM: enabled by default - CONFIG_DESIGNWARE_ETH : not being used anywhere. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-05-08stm32f7: sdram: correct sdram configuration as per micron sdramVikas Manocha
Actually the sdram memory on stm32f746 discovery board is micron part MT48LC_4M32_B2B5_6A. This patch does the modification required in the device tree node & driver for the same. Also we are passing here all the timing parameters in terms of clock cycles, so no need to convert time(ns or ms) to cycles. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-05-08stm32f7: enable board info read from device treeVikas Manocha
2017-05-08stm32f7: stm32f746-disco: read memory info from device treeVikas Manocha
2017-05-08stm32f746: to switch on user LED1 & read user buttonVikas Manocha
All discovery boards have one user button & one user LED. Here we are just reading the button status & switching ON the user LED. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-05-08stm32f7: use stm32f7 gpio driver supporting driver modelVikas Manocha
With this gpio driver supporting DM, there is no need to enable clocks for different gpios (for pin muxing) in the board specific code. Need to increase the allocatable area required before relocation from 0x400 to 0xC00 becuase of 10 new gpio devices(& new gpio class) added in device tree. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-08stm32f7: enable instruction & data cacheVikas Manocha
It also enables commands for cache enable/disable/status. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2017-01-28ARM: stm32: enable support for smsc phy on stm32f746-disco boardMichael Kurz
This patch enables support for the smsc phy on the stm32f746-disco board. Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Acked-by: Vikas MANOCHA <vikas.manocha@st.com> Series-changes 3: - Add Acked-by tag to 'enable support for smsc phy on...'
2017-01-28net: stm32: add designware mac glue code for stm32Michael Kurz
This patch adds glue code required for enabling the designware mac on stm32f7 devices. Signed-off-by: Michael Kurz <michi.kurz@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-07-14stm32: Add SDRAM support for stm32f746 discovery boardToshifumi NISHINAGA
This patch adds SDRAM support for stm32f746 discovery board. This patch depends on previous patch. This patch is based on STM32F4 and emcraft's[1]. [1]: https://github.com/EmcraftSystems/u-boot Signed-off-by: Toshifumi NISHINAGA <tnishinaga.dev@gmail.com>
2016-07-14stm32: clk: Add 200MHz clock configuration for stm32f746 discovery boardToshifumi NISHINAGA
This patch adds 200MHz clock configuration for stm32f746 discovery board. This patch is based on STM32F4 and emcraft's[1]. [1]: https://github.com/EmcraftSystems/u-boot Signed-off-by: Toshifumi NISHINAGA <tnishinaga.dev@gmail.com>
2016-04-18kconfig: Move CONFIG_OF_LIBFDT to KconfigMichal Simek
This patch follows work done by: "Move CONFIG_OF_LIBFDT to Kconfig" (sha1: 69e173eb57d1f4848f070c83456096ba5d2ba1b4) Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Add xpress* to the patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-26stm32f746-disco: enable flash supportVikas Manocha
This patch enables embedded flash for stm32f746 discovery board. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2016-02-24stm32: add support for stm32f7 & stm32f746 discovery boardVikas Manocha
This patch adds support for stm32f7 family & stm32f746 board. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
