path: root/include/configs/stm32f429-discovery.h
2018-08-13configs: stm32f4xx: Remove CONFIG_SYS_RAM_FREQ_DIVPatrice Chotard
Since commit bfea69ad2793 ("stm32f7: sdram: correct sdram configuration as per micron sdram"), CONFIG_SYS_RAM_FREQ_DIV flag is no more used, remove it. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13configs: stm32f4xx: Enable ICACHE and DCACHEPatrice Chotard
Enable instruction and data caches. Fix boot_sd command as since commit d409c962169b ("armv7m: disable icache before linux booting"), instruction cache is automatically disable before linux booting. "icache off" from boot_sd command becomes useless, remove it. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13configs: stm32f429-disco: Remove CONFIG_SYS_RAM_CSPatrice Chotard
This flag is not used, remove it. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13configs: stm32fxxx: Remove CONFIG_SYS_CLK_FREQPatrice Chotard
Since commit aa5e3e22f4d6 ("board: stm32: switch to DM STM32 timer") SYS_CLK_FREQ is useless, remove it from stm32f4 and stm32f7 boards. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-08-13board: stm32: use bi_dram[0].start instead of hardcoded valuePatrice Chotard
Use gd->bd->bi_dram[0].start initialized from DT instead of using hardcoded CONFIG_SYS_SDRAM_BASE from config file. Remove unused CONFIG_SYS_RAM_BASE and CONFIG_SYS_SDRAM_BASE defines. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-05-26ram: stm32_sdram: Adds stm32f429-disco fixes for HardFault at bootingRadoslaw Pietrzyk
- adds reading FMC swap setting from DTB to SDRAM driver - sets FMC swap for stm32f429-disco board - changes ram start address to 0x90000000 Signed-off-by: Radoslaw Pietrzyk <radoslaw.pietrzyk@gmail.com> Acked-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-09ARM: Drop unreferenced CONFIG_* defines named after boardsTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_AT91SAM9263EK CONFIG_AT91SAM9RLEK CONFIG_BARIX_IPAM390 CONFIG_BOARD_H2200 CONFIG_EP9301 CONFIG_KZM_A9_GT CONFIG_PICOSAM CONFIG_PLATINUM_PICON CONFIG_PLATINUM_TITANIUM CONFIG_PM9261 CONFIG_PM9263 CONFIG_PM9G45 CONFIG_SIEMENS_DRACO CONFIG_SIEMENS_PXM2 CONFIG_SIEMENS_RUT CONFIG_SMDKC100 CONFIG_SMDKV310 CONFIG_STM32F4DISCOVERY Most of them are config symbols named after the respective boards which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-02-08configs: stm32: Enable CONFIG_ENV_VARS_UBOOT_CONFIGPatrice Chotard
Enable CONFIG_ENV_VARS_UBOOT_CONFIG for all STM32 boards It allows to retrieve the SoC name into the "soc" environment variable. Signed-off-by: Christophe Priouzeau <christophe.priouzeau@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2018-01-28configs: stm32f: Remove STM32_HSE_HZ for all STM32F seriesPatrice Chotard
As clk_stm32f driver is able to retrieve HSE frequency from DT, CONFIG_STM32_HSE_HZ becomes useless. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-10board: stm32f429-disco: switch to DM STM32 pinctrl and gpio driverPatrice Chotard
Use available DM stm32f7_gpio.c and pinctrl_stm32.c drivers instead of board GPIO initialization. Remove stm32_gpio.c which is no more used and migrate structs stm32_gpio_regs and stm32_gpio_priv into arch-stm32f4/gpio.h to not break compilation. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-10board: stm32f429-disco: switch to DM STM32 serial driverPatrice Chotard
Remove serial_stm32.c driver and uart init from board file, use available DM serial_stm32x7.c driver compatible for STM32F4/F7 and H7 SoCs. The serial_stm32x7.c driver will be renamed later with a more generic name as it's shared with all STM32 Socs. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-01-10board: stm32f429-discovery: switch to DM STM32 sdram driverPatrice Chotard
Use available DM stm32_sdram.c driver instead of board SDRAM initialization. For that, enable OF_CONTROL, OF_EMBED and STM32_SDRAM flags. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-11Kconfig: Drop CONFIG_CMD_MEMSimon Glass
This is not actually used in U-Boot. Most likely it means CONFIG_CMD_MEMORY so change all occurences to that. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2016-06-13ARM: stm32: remove unused CONFIG_AUTOBOOTMasahiro Yamada
At this point, this is not referenced from anywhere, so remove it (but it will be re-added later for a different meaning). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-03-26stm32: stm32f4: move flash driver to mtd driver locationVikas Manocha
Same flash driver can be used by other stm32 families like stm32f7. Better place for this driver would be mtd driver location. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2016-01-20stm32: move stm32 specific code to mach-stm32Vikas Manocha
This patch moves stm32 sources at one place, with this armv7m now contains only generic stuff. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2015-12-12stm32: Convert serial driver to DMKamil Lulko
Signed-off-by: Kamil Lulko <kamil.lulko@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-10stm32f429-discovery: add CONFIG_SYS_THUMB_BUILDAlbert ARIBAUD
This target is ARMv7-M therefore can only build for Thumb, but it did not #define CONFIG_SYS_THUMB_BUILD, so the U-Boot code did not know it had to build for Thumb(2), not ARM. This patch is binary-invariant: builds of stm32f429-discovery with and without this patch were compared and found to differ only by their U-Boot version strings. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-07-27stm32f429: use 180 MHz system clockAntonio Borneo
Mainline Linux kernel commit 338a6aaabc02fa63b70441dd0e1b70aea64673c6 (ARM: dts: Introduce STM32F429 MCU) in arch/arm/boot/dts/stm32f429.dtsi requires U-Boot to set system clock to 180 MHz. Signed-off-by: Antonio Borneo <borneo.antonio@gmail.com> To: Albert Aribaud <albert.u.boot@aribaud.net> To: Tom Rini <trini@konsulko.com> To: Kamil Lulko <rev13@wp.pl> Cc: u-boot@lists.denx.de
2015-07-27stm32f429: pass the device unique ID in DTBAntonio Borneo
Read device unique ID and set environment variable "serial#". Value would then be passed to kernel through DTB. To read ID from DTB, kernel is required to have commit: 3f599875e5202986b350618a617527ab441bf206 (ARM: 8355/1: arch: Show the serial number from devicetree in cpuinfo) This commit is already mainline since v4.1-rc1. Signed-off-by: Antonio Borneo <borneo.antonio@gmail.com> To: Albert Aribaud <albert.u.boot@aribaud.net> To: Tom Rini <trini@konsulko.com> To: Kamil Lulko <rev13@wp.pl> Cc: u-boot@lists.denx.de
2015-07-27stm32f429-discovery: Use ttyS0 as the console devicerev13@wp.pl
Mainline kernel will be using this device name as well. Signed-off-by: Kamil Lulko <rev13@wp.pl>
2015-07-08stm32f4: fix gpio description in commentAntonio Borneo
On STM32F429 gpio PC6/PC7 can be allocated for USART6, as reported in the comment. But current code in drivers/serial/serial_stm32.c uses a different gpio mapping (PG14/PG9) for USART6. Fix the comment to match current code in the driver. Signed-off-by: Antonio Borneo <borneo.antonio@gmail.com> To: u-boot@lists.denx.de To: Kamil Lulko <rev13@wp.pl> Cc: Tom Rini <trini@konsulko.com>
2015-07-08stm32f4: fix minor typo in commentAntonio Borneo
2015-05-10stm32f4: add serial print portkunhuahuang
Add the stm32F4 board's serial ports support. User can use it easily. The user only need to edit the number of the usart. The patch also fix the serial print out. Last, this version of patch fix the first patch checkpatch.pl error. Thanks to Kamil Lulko. Signed-off-by: kunhuahuang <huangkunhua@gmail.com>
2015-04-22stm32f4: Add support for stm32f429-discovery boardrev13@wp.pl
Signed-off-by: Kamil Lulko <rev13@wp.pl> Reviewed-by: Tom Rini <trini@konsulko.com>
