path: root/include/configs/spear3xx_evb.h
2016-09-16spear: Use upper case for CONFIG optionsSimon Glass
There are a few options which use lower case. We should use upper case for all CONFIG options. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Add usbtty/nand hunk to include/configs/spear3xx_evb.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2012-07-07cleanup/SPEAr: Define configuration flags more elegantlyAmit Virdi
In SPEAr, some of the configuration flags eg. CONFIG_SPEAR_EMI, were given value "1", which isn't required. Define the flags without assigning any value Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07cleanup/SPEAr: Remove unnecessary parenthesisAmit Virdi
In SPEAr configuration files, unnecessary paranthesis are used in some \#defines. Remove them as they serve no purpose Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Enable CONFIG_SYS_FLASH_PROTECTIONVipin Kumar
This patch enables flash protection(lock/unlock) for CFI devices. This is necessary because the Parallel NOR flash connected on the spear boards, M28W64, can be locked/unlocked on a sector basis. Moreover, all its sectors are in locked state at reset and these have to be unlocked explicitly before being erased or written. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Change the default environment variablesVipin KUMAR
This patch modifies the default environment variables as: 1. Default bootargs: - console=ttyAMA0,115200 - For environment present in NOR flash root=/dev/mtdblock3 - For environment present in NAND flash root=/dev/mtdblock7 - Removes "mem=" option 2. Introduces CONFIG_EXTRA_ENV_USBTTY as default usbtty env var even when usbtty is not selected 3. Add default definitions for nfsboot and ramboot 4. Add a new default environment variable(CONFIG_EXTRA_ENV_UNLOCK) for SPEAr310 and SPEAr320 Signifacance of CONFIG_EXTRA_ENV_USBTTY: This environment variable is important for flashing utility to work. So if somebody accidently erases the env sector then also this variable must be preserved so that flashing utility functions properly. Signifacance of CONFIG_EXTRA_ENV_UNLOCK: This env variable is read by the cfi driver to unlock all flash sectors. This is necessary because the Parallel NOR flash connected on the spear310 and spear320 boards, M28W64, has all its sectors in locked state at reset and these have to be unlocked explicitly before being erased or written. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Add configuration options for spear3xx and spear6xx boardsVipin KUMAR
This patch adds options for all the below mentioned configurations and subsequently renames the include/configs/spearxxx.h files to spear3xx_evb.h, spear6xx_evb.h etc to depict evaluation board configuration. SPEAr3xx and SPEAr6xx boards can be compiled in following configurations 1. Environment placed in NAND 2. Console on usb device 3. Console on usb device with environment placed in NAND 4. SPEAr310 and SPEAr320 support environment variables in parallel NOR flash. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
