path: root/include/configs/spear-common.h
2018-01-28pl011: Convert CONFIG_PL011_SERIAL to KconfigAlexander Graf
We want to use Kconfig logic to depend on whether pl01x devices are built in, so let's convert their inclusion selection to Kconfig. This round goes to pl011. Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-03include/configs: remove numerous CONFIG_SYS_BARGSIZE definitionsThomas Petazzoni
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be equal to CONFIG_SYS_CBSIZE in numerous configuration files. We remove such definitions in two situations: - CONFIG_SYS_CBSIZE is otherwise not defined in the board configuration file, which means the default value of CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is larger. - CONFIG_SYS_CBSIZE is defined in the board configuration file, but to a value equal or less than 512. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it is equal or larger. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_SAVES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SAVES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-05-22Kconfig: Drop CONFIG_CMD_ENVSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-01autoboot: remove CONFIG_ZERO_BOOTDELAY_CHECKMasahiro Yamada
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2 means the autoboot with no delay, with no abort check even if CONFIG_ZERO_BOOTDELAY_CHECK is defined. To sum up, the autoboot behaves as follows: [1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n autoboot with no delay, with no check for abort [3] CONFIG_BOOTDELAY=-1 disable autoboot [4] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort As you notice, [2] and [4] come to the same result, which means we do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the cases only by CONFIG_BOOTDELAY, like this: [1] CONFIG_BOOTDELAY=0 autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=-1 disable autoboot [3] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort This commit converts the logic as follow: CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n --> CONFIG_BOOTDELAY=-2 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Christian Riesch <christian.riesch@omicronenergy.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2016-05-17i2c: config: Move SYS_I2C_DW to KconfigStefan Roese
This patch moves all appearances of CONFIG_SYS_I2C_DW from the config header to the defconfig files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Alexey Brodkin <abrodkin@synopsys.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-12-22net: eth_designware: select PHYLIB in KconfigThomas Chou
Select PHYLIB in drivers/net/Kconfig. And remove CONFIG_PHYLIB from legacy board header files. This fixed the warnings when both ALTERA_TSE and ETH_DESIGNWARE are selected. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reported-by: Pavel Machek <pavel@denx.de> Acked-by: Chin Liang See <clsee@altera.com> Acked-by: Pavel Machek <pavel@denx.de> Tested-by: Pavel Machek <pavel@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-28configs: remove remnants of CONFIG_SYS_NAND_QUIET_TESTIgor Grinberg
The config option has been removed by one of the syncs with the Linux mainline MTD subsystem: ff94bc40af (mtd, ubi, ubifs: resync with Linux-3.14) It has been left inside the config files. Currently does not look to serve any purpose, so remove it now from all the configs. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Stefan Roese <sr@denx.de> Cc: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Stefan Roese <sr@denx.de>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-03-05arm: spear: Move to generic board supportStefan Roese
Without this change the board support for these SPEAr boards would be dropped soon. Generic board support seems to work just fine. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Vipin Kumar <vk.vipin@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
2014-10-29i2c: designware: Convert driver to multibus/multiadapter frameworkStefan Roese
In preparation for the SoCFPGA support of the designware I2C driver, convert this driver to the common CONFIG_SYS_I2C framework. This patch converts all users of this driver, this is: - ST spearxxx boards - AXS101 (ARC700 platform) I couldn't test this patch on those boards. Only compile tested for all spear boards. And tested on SoCFPGA. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Tested-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Heiko Schocher <hs@denx.de> Cc: Vipin Kumar <vk.vipin@gmail.com> Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-02-20spear: move CONFIG_SYS_I2C_BASE from arch-spear/hardware to board configsAlexey Brodkin
Having CONFIG_SYS_I2C_BASE requires DW I2C driver to explicitly include <arch/hardware.h> which other platforms may not have at all. It's always good to have a driver platform-independent. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Armando Visconti <armando.visconti@st.com>
2014-02-07net/designware - switch driver to phylib usageAlexey Brodkin
With this change driver will benefit from existing phylib and thus custom phy functionality implemented in the driver will go away: * Instantiation of the driver is now much shorter - 2 parameters instead of 4. * Simplified phy management/functoinality in driver is replaced with rich functionality of phylib. * Support of custom phy initialization is now done with existing "board_phy_config". Note that after this change some previously used config options (driver-specific PHY configuration) will be obsolete and they are simply substituted with similar options of phylib. For example: * CONFIG_DW_AUTONEG - no need in this one. Autonegotiation is enabled by default. * CONFIG_DW_SEARCH_PHY - if one wants to specify attached phy explicitly CONFIG_PHY_ADDR board config option has to be used, otherwise automatically the first discovered on MDIO bus phy will be used I believe there's no need now in "doc/README.designware_eth" because user only needs to instantiate the driver with "designware_initialize" whose prototype exists in "include/netdev.h". Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Amit Virdi <amit.virdi@st.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-07-07net: Multiple updates/enhancements to designware.cStefan Roese
This patch adds the following changes to designware ethernet driver found on the ST SPEAr SoC: - Don't init MAC & PHY upon startup. This causes a delay, waiting for the auto negotiation to complete. And we don't want this delay to always happen. Especially not on platforms where ethernet is not used at all (e.g. booting via flash). Instead postpone the MAC / PHY configuration to the stage, where ethernet is first used. - Add possibility for board specific PHY init code. This is needed for example on the X600 board, where the Vitesse PHY needs to be configured for GMII mode. This board specific PHY init is done via the function designware_board_phy_init(). And this driver now adds a weak default which can be overridden by board code. - Use common functions miiphy_speed() & miiphy_duplex() to read link status from PHY. - Print status and progress of auto negotiation. - Print link status (speed, dupex) upon first usage. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Amit Virdi <amit.virdi@st.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@gmail.com>
2012-07-07cleanup/SPEAr: Define configuration flags more elegantlyAmit Virdi
In SPEAr, some of the configuration flags eg. CONFIG_SPEAR_EMI, were given value "1", which isn't required. Define the flags without assigning any value Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07cleanup/SPEAr: Remove unnecessary parenthesisAmit Virdi
In SPEAr configuration files, unnecessary paranthesis are used in some \#defines. Remove them as they serve no purpose Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Remove CONFIG_MTD_NAND_VERIFY_WRITE to speed up NAND accessAmit Virdi
When CONFIG_MTD_NAND_VERIFY_WRITE is defined, nand driver read back the data everytime it writes. This process unnecessarily slows down the nand access. Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Enable ONFI nand flash detection for spear3xx and 6xx and evbVipin Kumar
Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Enable CONFIG_SYS_FLASH_EMPTY_INFO macroVipin Kumar
Enable CONFIG_SYS_FLASH_EMPTY_INFO macro to enable reporting of empty sector information through flinfo command. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Correct the definition of CONFIG_SYS_MONITOR_BASEVipin Kumar
The below text is copy pasted from README - CONFIG_SYS_MONITOR_BASE: Physical start address of boot monitor code (set by make config files to be same as the text base address (TEXT_BASE) used when linking) - same as CONFIG_SYS_FLASH_BASE when booting from flash. This patch corrects the definition of CONFIG_SYS_MONITOR_BASE and sets it to TEXT_BASE Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Enable autoneg for ethernetShiraz Hashim
Enabling autoneg avoids situation on few phys with fixed configuration. For example, in one situation, nfs boot timed out when phy configuration is 100Mbps. In another situtation, when traffic is directed to SPEAr, either thru cross-cable or thru switch, the TFTP or DHCP command in u-boot starts to timeout very often. When Autoneg is ON, same phys started working perfectly. Reported-by: Deepak Sikri <deepak.sikri@st.com> Reported-by: Armando Visconti <armando.visconti@st.com> Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Enable udc and usb-console support only for usbtty configurationVipin KUMAR
This patch enables the UDC and usb-console support only for usbtty configurations Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Enable usb device high speed supportVipin KUMAR
This patch enables the support for usb high speed device for spear platform SOCs Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
