path: root/include/configs/spear-common.h
2011-08-04spear: fix build errors for spear3xx/spear600 platformsShiraz Hashim
Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Acked-by: Vipin Kumar <vipin.kumar@st.com>
2010-01-23SPEAr : Support added for SPEAr600 boardVipin KUMAR
SPEAr600 SoC support contains basic spear600 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver Signed-off-by: Vipin <vipin.kumar@st.com>
