path: root/include/configs/socrates.h
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-08-01powerpc/85xx: configure autocompletion supportKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-2685xx/socrates: Remove NFS support to fit image size.Detlev Zundel
This fixes an overflow during the link phase. Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-31video: mb862xx: add option VIDEO_FB_16BPP_WORD_SWAP for IPEK01Wolfgang Grandegger
In 16 bpp mode, the new IPEK01 board only requires swapping of D16 words for D32 accesses due to the diffferent connecting to the GDC bus. This patch introduces the configuration option VIDEO_FB_16BPP_WORD_SWAP, which should be set for all board using the mb862xx in 16 bpp mode. For the IPEK01, VIDEO_FB_16BPP_PIXEL_SWAP should not be set. Signed-off-by: Wolfgang Grandegger <wg@denx.de>
2009-10-31video: mb862xx: add option CONFIG_VIDEO_MB862xx_ACCEL for 32bpp modeAnatolij Gustschin
The new IPEK01 board can use the 32 bpp mode for the Lime graphics controller. For this mode, video accelaration does not work. This patch makes the accelaration configurable via CONFIG_VIDEO_MB862xx_ACCEL, which is enabled for the lwmon5 and the socrates board for backward compatibility. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Wolfgang Grandegger <wg@denx.de>
2009-10-31video: mb862xx: improve board-specific Lime configurationWolfgang Grandegger
To avoid board-specific code accessing the mb862xx registers directly, the public function mb862xx_probe() has been introduced. Furthermore, the "Change of Clock Frequency" and "Set Memory I/F Mode" registers are now defined by CONFIG_SYS_MB862xx_CCF and CONFIG_SYS_MB862xx__MMR, respectively. The BSPs for the socrates and lwmon5 boards have been adapted accordingly. Signed-off-by: Wolfgang Grandegger <wg@denx.de>
2009-07-18NAND: Fix warning Please define CONFIG_SYS_64BIT_VSPRINTF...Wolfgang Denk
Commit 8d2effea added a warning for configurations that use NAND without defining the (then necessary) CONFIG_SYS_64BIT_VSPRINTF but failed to fix the affected boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12i2c: Remove deprecated individual i2c commandsPeter Tyser
The following individual I2C commands have been removed: imd, imm, inm, imw, icrc32, iprobe, iloop, isdram. The functionality of the individual commands is still available via the 'i2c' command. This change only has an impact on those boards which did not have CONFIG_I2C_CMD_TREE defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-12-14Remove unused CONFIG_ADDR_STREAMING definesPeter Tyser
2008-12-01Removed unused CONFIG_L1_INIT_RAM symbol.Jon Loeliger
Prevent further viral propogation of the unused symbol CONFIG_L1_INIT_RAM by just removing it. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-09-22socrates: change default mtest address rangeAnatolij Gustschin
Running mtest command on socrates without specifying an address range crashes the board. This patch changes default mtest address range to prevent this behavior. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-22socrates: fix SPD EEPROM addressAnatolij Gustschin
Commit be0bd8234b9777ecd63c4c686f72af070d886517 changed SPD EEPROM address to 0x51 and DDR SDRAM detection stopped working. Change this address back to 0x50. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-1385xx: socrates: Add support for new image format.u-boot@bugs.denx.de
2008-09-0985xx: socrates: Enable Lime support.Anatolij Gustschin
This patch adds Lime GDC support together with support for the PWM backlight control through the w83782d chip. The reset pin of the latter is attached to GPIO, so we need to reset it in early_board_init_r. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-0985xx: Socrates: Major code update.Detlev Zundel
- Update the local bus ranges in the FDT for Linux for the various devices connected to the local bus via chip-select. - Set the LCRR_DBYP bit in the LCRR for local bus frequencies lower than 66 MHz and uses I/O accessor functions consequently. - UPM data update. - Update of default environment and configuration. Use I2C multibus as we do have two I2C buses. Also enable sdram and ext2 commands. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-09-06USB EHCI: reset root hubYuri Tikhonov
Some of multi-function USB controllers (e.g. ISP1562) allow root hub resetting only via EHCI registers. So, this patch adds the corresponding kind of reset to OHCI's hc_reset() if the newly introduced CONFIG_PCI_EHCI_DEVNO option is set (e.g. for Socrates board). Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Acked-by: Markus Klotzbuecher <mk@denx.de>
2008-08-27FSL DDR: Convert socrates to new DDR code.Kumar Gala
2008-06-11Socrates: NAND support added. Changed the U-Boot base address andSergei Poselenov
2008-06-11Socrates: Added FPGA mapping. LAWs and TLBs cleanup.Sergei Poselenov
2008-06-11Socrates: config file cleanup.Sergei Poselenov
2008-05-27Socrates: Fix PCI bus frequency reportSergei Poselenov
2008-05-27Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
Conflicts: include/configs/socrates.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-27Socrates: Added USB support.Sergei Poselenov
2008-05-27Socrates: add support for DS75 Digital Thermo Sensor on I2C bus.Sergei Poselenov
2008-05-27Socrates: Config file cleanup.Sergei Poselenov
2008-05-22USB: add support for multiple PCI OHCI controllersSergei Poselenov
Add new configuration variable CONFIG_PCI_OHCI_DEVNO. In case of several PCI USB controllers on a board this variable specifys which controller to use. Also add USB support for sokrates board. See doc/README.generic_usb_ohci for details. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-05-20socrates: fix second TSEC configuration (it is actually TSEC3)Sergei Poselenov
2008-05-20socrates: changes to support FDTSergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-20Initial support for "Socrates" boardSergei Poselenov
