Running mtest command on socrates without specifying
an address range crashes the board. This patch changes
default mtest address range to prevent this behavior.
Commit be0bd8234b9777ecd63c4c686f72af070d886517
changed SPD EEPROM address to 0x51 and DDR SDRAM
detection stopped working. Change this address
back to 0x50.
Signed-off-by: Detlev Zundel <dzu@denx.de>
This patch adds Lime GDC support together with support for the PWM
backlight control through the w83782d chip. The reset pin of the
latter is attached to GPIO, so we need to reset it in
early_board_init_r.
- Update the local bus ranges in the FDT for Linux for the various
devices connected to the local bus via chip-select.
- Set the LCRR_DBYP bit in the LCRR for local bus frequencies
lower than 66 MHz and uses I/O accessor functions consequently.
- UPM data update.
- Update of default environment and configuration. Use I2C multibus
as we do have two I2C buses. Also enable sdram and ext2 commands.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Some of multi-function USB controllers (e.g. ISP1562) allow root hub
resetting only via EHCI registers. So, this patch adds the
corresponding kind of reset to OHCI's hc_reset() if the newly
introduced CONFIG_PCI_EHCI_DEVNO option is set (e.g. for Socrates
board).
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Acked-by: Markus Klotzbuecher <mk@denx.de>
rename CFG_FLASH_CFI_DRIVER to CONFIG_FLASH_CFI_DRIVER
include/configs/socrates.h
Add new configuration variable CONFIG_PCI_OHCI_DEVNO.
In case of several PCI USB controllers on a board this variable
specifys which controller to use.
Also add USB support for sokrates board.
See doc/README.generic_usb_ohci for details.
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
