CONFIG_SYS_BOOTCOUNT_LE
CONFIG_SYS_BOOTCOUNT_BE
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
- In most of the codebase, we reference CONFIG_SYS_LOAD_ADDR and not
CONFIG_LOADADDR.
- Generally, CONFIG_SYS_LOADADDR is set to CONFIG_LOADADDR and then as
noted, we use CONFIG_SYS_LOADADDR.
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Move this symbol to Kconfig. As part of this we can drop a UBI-specific
symbol that was a stop-gap for not having this particular symbol in
Kconfig.
Remove outdated defines (not used any more, outdated due to DM
conversion) from various socfpga files in include/config.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Series-version: 3
Series-changes: 2
- added (this) patch with further cleanups to the socfpga board config
files
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MAX_HZ
CONFIG_ENV_SPI_MODE
Most of time these value are not needed, CONFIG_SF_DEFAULT
with same value is used, so I introduced CONFIG_USE_ENV_SPI_*
to force the associated value for the environment.
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
The CONFIG_PHY_MARVELL has already been migrated to Kconfig (some boards
already had it in their Kconfig), but had not been moved for older
boards.
Move it to the defconfigs for all boards.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Migrate the users of CONFIG_SYS_BOOTCOUNT_ADDR to Kconfig. We can
provide a default for BOOTCOUNT_AM33XX as that's a specific part of the
RTC in use. We can also provide a default for ARCH_LS1043A and
ARCH_LS1021A as they had been previously calculated and their symbols
are in Kconfig. In the case of other QE-enabled platforms, they are not
so we must update the relevant defconfig files. The previous default
only applied in some cases, even on a specific SoC family.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Alex Kiernan <alex.kiernan@gmail.com>
All Socfpga boards from ./include/configs/socfpga_* define
CONFIG_HW_WATCHDOG.
To ease CONFIG_HW_WATCHDOG conversion to Kconfig select it in
config ARCH_SOCFPGA (arch/arm/Kconfig) section.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
CONFIG_BOOTCOUNT_LIMIT
Tested-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
CONFIG_ENV_IS_IN_SPI_FLASH
Now that these symbols are in Kconfig, migrate all users. Use imply on
a number of platforms that default to having this enabled. As part of
this we must migrate some straglers for CMD_FAT and DOS_PARTITION.
This removes the default environment from the sr1500 header
and instead uses the common environment provided in
socfpga_common.h which now uses distro boot.
This board has no upstream devicetree in the kernel source,
so set to socfpga_cyclone5_sr1500.dtb.
Signed-off-by: Dalon Westergreen <dwesterg@gmail.com>
Changes in v2:
- Remove unneeded CONFIG_BOOTFILE
- set devicetree name to match socfpga_{fpga model}_{board model}.dts
pattern
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_BOARD_EARLY_INIT_F
CONFIG_SYS_CONSOLE_INFO_QUIET
[trini: Make this default n, re-run the migration]
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Somehow the sr1500 is missing this comma in the CONFIG_BOOTARGS
definition. This patch adds it to.
Reported-by: Pavel Machek <pavel@denx.de>
Cc: Pavel Machek <pavel@denx.de>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There is an incorrect space after loadaddr= in the extra environment,
so drop it.
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Chin Liang See <clsee@altera.com>
This patch makes the following changes to the SR1500 board port:
- Update defconfig to support SPI NOR (use make savedefconfig).
- Increase SPI speed to a maximum of 100MHz for faster system
bootup.
- Change environment location, so that its not between SPL and
main U-Boot. This way the combined SPL / U-Boot image can
be used for updates.
Move the inclusion of the common socfpga configuration file further
down in the sr1500 configuration, so that the socfpga_common.h can
check if environment is in SPI NOR and it's location is defined and
if it is not, define default location.
This fixes "arm: socfpga: Enabling U-Boot environment support in QSPI"
which introduced a minor warning.
Cc: Dinh Nguyen <dinh.linux@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Update the qspiboot console command to use UBIFS instead
of old jffs2 file system.
Signed-off-by: Chin Liang See <clsee@altera.com>
Enabling qspiload command which will load the kernel
image and dtb from UBIFS within MTD partition labeled
UBI.
Enabling ubiload command to load kernel image and
device tree from mtd part labeled "UBI". ubiload
command will search the file from directory /boot.
We already have the CONFIG_SYS_BOARD variable, which defines the name
of the board. The value in CONFIG_HOSTNAME is exactly the same and is
thus just a duplicity, so switch it to reuse CONFIG_SYS_BOARD .
The SR1500 board is a CycloneV based board, similar to the EBV
SoCrates, equipped with the following devices:
- SPI NOR
- eMMC
- Ethernet
Acked-by: Pavel Machek <pavel@denx.de>
