path: root/include/configs/socfpga_socrates.h
2016-04-10arm: socfpga: Drop space after 'loadaddr=' in extra envMarek Vasut
There is an incorrect space after loadaddr= in the extra environment, so drop it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Chin Liang See <clsee@altera.com>
2015-12-22arm: socfpga: socrates: Consolidate SDMMC environmentChin Liang See
Remove the duplication of SDMMC environment configuration from each boards' configuration header file into socfpga_common.h Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
2015-12-20arm: socfpga: Switch CONFIG_HOSTNAME to CONFIG_SYS_BOARDMarek Vasut
We already have the CONFIG_SYS_BOARD variable, which defines the name of the board. The value in CONFIG_HOSTNAME is exactly the same and is thus just a duplicity, so switch it to reuse CONFIG_SYS_BOARD . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: Switch CONFIG_G_DNL_MANUFACTURER to CONFIG_SYS_VENDORMarek Vasut
We already have the CONFIG_SYS_VENDOR variable, which defines the manufacturer of the board. The value in CONFIG_G_DNL_MANUFACTURER is just a duplicity, so switch it to reuse CONFIG_SYS_VENDOR . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: socrates: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
This patch adds the necessary OF alias for the UDC node, which let's the code locate the DWC2 UDC base address in OF instead of hard-coding it into the U-Boot binary. The code is adjusted to use the address from OF instead of the hard-coded one. Finally, the hard-coded address is removed and USB DM support is enabled. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Lukasz Majewski <l.majewski@majess.pl> Cc: Lukasz Majewski <l.majewski@samsung.com>
2015-12-20arm: socfpga: socrates: Remove Micrel PHY configurationMarek Vasut
The Micrel PHY configuration is now done from OF, so hard-coding the configuration into the board file is no longer necessary. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-11-30arm: socfpga: Remove fsloadcmd from environmentChin Liang See
Remove fsloadcmd / ext2load as we are using load command which use the corresponding latest file system command. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2015-11-30arm: socfpga: Repair SoCrates boardMarek Vasut
This board was constantly parasiting on the CV SoCDK, so split it into it's own separate directory. Moreover, the board config was missing important bits, like simple-bus support in SPL, the DRAM configuration was incorrect and the DTS was also missing the pre reloc bits. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Jan Viktorin <viktorin@rehivetech.com>
