path: root/include/configs/socfpga_sockit.h
2016-04-10arm: socfpga: Drop space after 'loadaddr=' in extra envMarek Vasut
There is an incorrect space after loadaddr= in the extra environment, so drop it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Chin Liang See <clsee@altera.com>
2015-12-22arm: socfpga: sockit: Update qspiboot to use UBIFSChin Liang See
Update the qspiboot console command to use UBIFS instead of old jffs2 file system. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
2015-12-22arm: socfpga: sockit: Enable qspiload console commandChin Liang See
Enabling qspiload command which will load the kernel image and dtb from UBIFS within MTD partition labeled UBI. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
2015-12-22arm: socfpga: sockit: Enable ubiload console commandChin Liang See
Enabling ubiload command to load kernel image and device tree from mtd part labeled "UBI". ubiload command will search the file from directory /boot. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
2015-12-22arm: socfpga: sockit: Consolidate SDMMC environmentChin Liang See
Remove the duplication of SDMMC environment configuration from each boards' configuration header file into socfpga_common.h Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
2015-12-20arm: socfpga: Switch CONFIG_HOSTNAME to CONFIG_SYS_BOARDMarek Vasut
We already have the CONFIG_SYS_BOARD variable, which defines the name of the board. The value in CONFIG_HOSTNAME is exactly the same and is thus just a duplicity, so switch it to reuse CONFIG_SYS_BOARD . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: Switch CONFIG_G_DNL_MANUFACTURER to CONFIG_SYS_VENDORMarek Vasut
We already have the CONFIG_SYS_VENDOR variable, which defines the manufacturer of the board. The value in CONFIG_G_DNL_MANUFACTURER is just a duplicity, so switch it to reuse CONFIG_SYS_VENDOR . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: sockit: Zap VIRTUAL_TARGETMarek Vasut
There is no VT for this board, so remove this incorrect macro. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: sockit: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
This patch adds the necessary OF alias for the UDC node, which let's the code locate the DWC2 UDC base address in OF instead of hard-coding it into the U-Boot binary. The code is adjusted to use the address from OF instead of the hard-coded one. Finally, the hard-coded address is removed and USB DM support is enabled. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Lukasz Majewski <l.majewski@majess.pl> Cc: Lukasz Majewski <l.majewski@samsung.com>
2015-12-20arm: socfpga: sockit: Remove Micrel PHY configurationMarek Vasut
The Micrel PHY configuration is now done from OF, so hard-coding the configuration into the board file is no longer necessary. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-11-30arm: socfpga: Remove fsloadcmd from environmentChin Liang See
Remove fsloadcmd / ext2load as we are using load command which use the corresponding latest file system command. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2015-11-30ARM: socfpga: rename the cyclone5 and arria5 base address fileDinh Nguyen
When adding support for the Arria10 platform, we're going to name the file base_addr_a10.h, so to be systematic about it, rename the socfpga_base_addr.h to be base_addr_ac5.h for the Arria5 and Cyclone5 platform. Suggested-by: Marek Vasut <marex@denx.de> Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-09-24arm: socfpga: Enable saveenv for SD/MMCDinh Nguyen
Enable the able to save the environment variables when SD/MMC is used. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-09-04arm: socfpga: Add support for Terasic SoCkit boardMarek Vasut
Add support for Terasic SoCkit, which is CycloneV based board. The board can boot either from SD/MMC or QSPI. Ethernet is also supported. Signed-off-by: Marek Vasut <marex@denx.de>
