There is an incorrect space after loadaddr= in the extra environment,
so drop it.
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Chin Liang See <clsee@altera.com>
Update the qspiboot console command to use UBIFS instead
of old jffs2 file system.
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinh.linux@gmail.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Stefan Roese <sr@denx.de>
Enabling qspiload command which will load the kernel
image and dtb from UBIFS within MTD partition labeled
UBI.
Enabling ubiload command to load kernel image and
device tree from mtd part labeled "UBI". ubiload
command will search the file from directory /boot.
Remove the duplication of SDMMC environment configuration
from each boards' configuration header file into
socfpga_common.h
We already have the CONFIG_SYS_BOARD variable, which defines the name
of the board. The value in CONFIG_HOSTNAME is exactly the same and is
thus just a duplicity, so switch it to reuse CONFIG_SYS_BOARD .
We already have the CONFIG_SYS_VENDOR variable, which defines the
manufacturer of the board. The value in CONFIG_G_DNL_MANUFACTURER
is just a duplicity, so switch it to reuse CONFIG_SYS_VENDOR .
There is no VT for this board, so remove this incorrect macro.
This patch adds the necessary OF alias for the UDC node, which let's
the code locate the DWC2 UDC base address in OF instead of hard-coding
it into the U-Boot binary. The code is adjusted to use the address from
OF instead of the hard-coded one. Finally, the hard-coded address is
removed and USB DM support is enabled.
Cc: Lukasz Majewski <l.majewski@majess.pl>
Cc: Lukasz Majewski <l.majewski@samsung.com>
The Micrel PHY configuration is now done from OF, so hard-coding
the configuration into the board file is no longer necessary.
Remove fsloadcmd / ext2load as we are using load command
which use the corresponding latest file system command.
When adding support for the Arria10 platform, we're going to name the file
base_addr_a10.h, so to be systematic about it, rename the socfpga_base_addr.h
to be base_addr_ac5.h for the Arria5 and Cyclone5 platform.
Suggested-by: Marek Vasut <marex@denx.de>
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Enable the able to save the environment variables when SD/MMC is used.
Add support for Terasic SoCkit, which is CycloneV based board.
The board can boot either from SD/MMC or QSPI. Ethernet is also
supported.
