path: root/include/configs/socfpga_de0_nano_soc.h
2019-04-25arm: socfpga: clean up board config filesSimon Goldschmidt
Remove outdated defines (not used any more, outdated due to DM conversion) from various socfpga files in include/config. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Series-version: 3 Series-changes: 2 - added (this) patch with further cleanups to the socfpga board config files
2018-02-15Convert socfpga: select CONFIG_HW_WATCHDOG support for ARCH_SOCFPGALukasz Majewski
All Socfpga boards from ./include/configs/socfpga_* define CONFIG_HW_WATCHDOG. To ease CONFIG_HW_WATCHDOG conversion to Kconfig select it in config ARCH_SOCFPGA (arch/arm/Kconfig) section. Signed-off-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-08-07configs: Replace deprecated Micrel defines with PHY_MICREL_KSZ90X1Alexandru Gagniuc
These boards will now use the ksz90x1 driver instead of the mess in ksz8xxx. This change is needed before the two drivers can be fully separated. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-14arm: socfpga: DE0 use environment in common headerDalon Westergreen
This removes the default environment from the de0 headers and instead uses the common environment provided in socfpga_common.h which now uses distro boot. In addition to the above, add support to boot from the custom a2 type partition Signed-off-by: Dalon Westergreen <dwesterg@gmail.com> Acked-by: Marek Vasut <marex@denx.de> -- Changes in v2: - Remove unneeded CONFIG_BOOTFILE
2016-04-10arm: socfpga: Drop space after 'loadaddr=' in extra envMarek Vasut
There is an incorrect space after loadaddr= in the extra environment, so drop it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Chin Liang See <clsee@altera.com>
2015-12-22arm: socfpga: de0_nano_soc: Consolidate SDMMC environmentChin Liang See
Remove the duplication of SDMMC environment configuration from each boards' configuration header file into socfpga_common.h Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de>
2015-12-20arm: socfpga: Switch CONFIG_HOSTNAME to CONFIG_SYS_BOARDMarek Vasut
We already have the CONFIG_SYS_BOARD variable, which defines the name of the board. The value in CONFIG_HOSTNAME is exactly the same and is thus just a duplicity, so switch it to reuse CONFIG_SYS_BOARD . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: Switch CONFIG_G_DNL_MANUFACTURER to CONFIG_SYS_VENDORMarek Vasut
We already have the CONFIG_SYS_VENDOR variable, which defines the manufacturer of the board. The value in CONFIG_G_DNL_MANUFACTURER is just a duplicity, so switch it to reuse CONFIG_SYS_VENDOR . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: de0_nano: Zap VIRTUAL_TARGETMarek Vasut
There is no VT for this board, so remove this incorrect macro. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: de0_nano: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
This patch adds the necessary OF alias for the UDC node, which let's the code locate the DWC2 UDC base address in OF instead of hard-coding it into the U-Boot binary. The code is adjusted to use the address from OF instead of the hard-coded one. Finally, the hard-coded address is removed and USB DM support is enabled. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Lukasz Majewski <l.majewski@majess.pl> Cc: Lukasz Majewski <l.majewski@samsung.com>
2015-12-20arm: socfpga: de0_nano: Remove Micrel PHY configurationMarek Vasut
The Micrel PHY configuration is now done from OF, so hard-coding the configuration into the board file is no longer necessary. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-11-30arm: socfpga: Remove fsloadcmd from environmentChin Liang See
Remove fsloadcmd / ext2load as we are using load command which use the corresponding latest file system command. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2015-11-30ARM: socfpga: rename the cyclone5 and arria5 base address fileDinh Nguyen
When adding support for the Arria10 platform, we're going to name the file base_addr_a10.h, so to be systematic about it, rename the socfpga_base_addr.h to be base_addr_ac5.h for the Arria5 and Cyclone5 platform. Suggested-by: Marek Vasut <marex@denx.de> Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-09-24arm: socfpga: Enable saveenv for SD/MMCDinh Nguyen
Enable the able to save the environment variables when SD/MMC is used. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-09-04arm: socfpga: Add support for the Terasic DE-0 Atlas boardDinh Nguyen
Add support for the Terasic DE0-Nano/Atlas-SoC Kit, which is a CycloneV based board. The board can boot from SD/MMC. Ethernet is also supported. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
