When QSPI and NAND is enabled, the ubi and ubifs support
will be enabled too.
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Dinh Nguyen <dinh.linux@gmail.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Stefan Roese <sr@denx.de>
Enabling MTD default partitions if its not defined in board
configuration file. The layout as below
device nor0 <ff705000.spi.0>, # parts = 6
#: name size offset mask_flags
0: u-boot 0x00100000 0x00000000 0
1: env1 0x00040000 0x00100000 0
2: env2 0x00040000 0x00140000 0
3: UBI 0x03e80000 0x00180000 0
4: boot 0x00e80000 0x00180000 0
5: rootfs 0x01000000 0x01000000 0
Remove the duplication of SDMMC environment configuration
from each boards' configuration header file into
socfpga_common.h
Select PHYLIB in drivers/net/Kconfig. And remove CONFIG_PHYLIB
from legacy board header files.
This fixed the warnings when both ALTERA_TSE and ETH_DESIGNWARE
are selected.
Reported-by: Pavel Machek <pavel@denx.de>
Acked-by: Chin Liang See <clsee@altera.com>
Acked-by: Pavel Machek <pavel@denx.de>
Tested-by: Pavel Machek <pavel@denx.de>
Replace__CONFIG_SOCFPGA_CYCLONE5_COMMON_H__ with
__CONFIG_SOCFPGA_COMMON_H__ as the file is now called socfpga_common.h
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Now that the USB DWC2 probing is done from OF, remove this note to add
CONFIG_USB_DWC2_REG_ADDR.
We already have the CONFIG_SYS_BOARD variable, which defines the name
of the board. The value in CONFIG_HOSTNAME is exactly the same and is
thus just a duplicity, so switch it to reuse CONFIG_SYS_BOARD .
Cc: Chin Liang See <clsee@altera.com>
We already have the CONFIG_SYS_VENDOR variable, which defines the
manufacturer of the board. The value in CONFIG_G_DNL_MANUFACTURER
is just a duplicity, so switch it to reuse CONFIG_SYS_VENDOR .
The s3c-otg IP block is in fact a DWC2 OTG one, so finally rename the
config option to make it less misleading. No functional change, just
a mechanical change done using the following script:
git grep USB_GADGET_S3C_UDC_OTG | cut -d : -f 1 | sort -u | \
while read line ; do
sed -i "s/USB_GADGET_S3C_UDC_OTG/USB_GADGET_DWC2_OTG/g" $line ;
done
socfpga_dw_mmc driver will obtain the drvsel and
smplsel value from device tree instead of definition
in config header file.
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
There are already Kconfig options for SPI drivers, but we
commit does this in a batch.
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Enable the able to save the environment variables when SD/MMC is used.
By not defining CONFIG_SYS_ARM_CACHE_WRITEALLOC, the WRITEBACK cache
policy is selected. This leads to much better performance on the SoCFPGA.
A quick network test shows this:
Without this patch:
=> tftp 100000 big-40mb
Speed: 1000, full duplex
Using dwmac.ff702000 device
TFTP from server 192.168.1.54; our IP address is 192.168.1.252
Filename 'big-40mb'.
Load address: 0x100000
Loading: #################################################################
2.5 MiB/s
With this patch:
7.6 MiB/s
A performance improvement of factor ~3.
The CONFIG_OF_CONTROL and CONFIG_SPL_OF_CONTROL is always enabled
on Altera SoCFPGA, remove the unnecessary checks.
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing
devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear
away the ugly logic in include/fdtdec.h:
#ifdef CONFIG_OF_CONTROL
# if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL)
# define OF_CONTROL 0
# else
# define OF_CONTROL 1
# endif
#else
#endif
Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to
CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for
SPL.
Also, we no longer have to cancel CONFIG_OF_CONTROL in
include/config_uncmd_spl.h and scripts/Makefile.spl.
Enable the mtdparts command and related options to make support
for SPI NOR MTD useful in any way. With the mtdparts command in
place, it is possible to use partition of the SPI NOR in U-Boot.
This is needed to access broken (read: Micron) SPI flashes which
are larger than 16 MiB and don't correctly support 4-byte addressing.
We do not need full MTD support in the SPL build, it only adds size
and is not usable in any way. Exclude it.
There is no need to disable support for partitions in the SPL,
we can support partitions in SPL perfectly well. This is likely
some remnant from old times, so just remove this configuration
option.
Moreover, the CRC32 chunk size doesn't have to be adjusted anymore,
since both the GD and malloc area are in RAM by the time this CRC
check can be used and there's plenty of space. Zap this abomination
as well.
Now that the SPL structure is organised such that it matches the
U-Boot's SPL design, it is possible to use the option of relocating
GD to RAM. And since we have GD in RAM, move malloc area to RAM as
well. We point the malloc base pointer 1 MiB past U-Boot's load
address. We use simple malloc for SPL because it is 3kiB smaller
in terms of code size than regular malloc which was used thus far.
setenv an environment variable called "bootmode" , which contains the
board boot mode. This can be in turn used in scripts to determine from
where to load kernel and such.
Add code and configuration options to support booting from QSPI NOR.
Enable support for booting from QSPI NOR.
Add code and configuration options to support booting from RAW
SD/MMC card as well as for ext4/vfat filesystems. Enable support
for booting from SD/MMC card, but don't enable the filesystem
support just yet to retain compatibility with old SoCFPGA card
format.
Remove the custom SPL linker script, use the generic one instead.
The custom script doesn't bring in anything new and is only burden
to maintain.
The code in spl_board_init() should have been in board_init_f()
from the beginning, since it is code which configures system and
then starts DRAM. Thus, it cannot be in spl_board_init(), which
is called from board_init_r() , which already expects a working
DRAM.
Enable the Altera SDRAM driver for the SoCFPGA platform.
This introduces a coherent scheme for naming USB download gadget and functions
config options. The download USB gadget config option is moved to
CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each
function's config option is moved to a CONFIG_USB_FUNCTION_ prefix.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed
from the configs.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
Replace CONFIG_SOCFPGA with CONFIG_ARCH_SOCFPGA.
Our recent trend is to collect SoC files into arch/arm/mach-(SOC).
We need to adjust the SYS_INIT_RAM_SIZE to have room for the
SPL_MALLOC_SIZE.
The Cyclone5 SoCFPGA has 64KB of OCRAM for SPL use.
Move this to Kconfig and clean up board config files that use it. Also
rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists
Version 1:
Zap this unused empty function, no point in having it.
Cc: Chin Liang See <clsee@opensource.altera.com>
Acked-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Vince Bridgers <vbridger@opensource.altera.com>
Since all boards now have a DT, instead of hard-coding the board
name into the U-Boot binary, read the board name from DT "model"
property.
Remove driver model CONFIGs from the board config headers and use Kconfig
instead.
The current current watchdog timeout of 12 seconds is a bit small for
booting into Linux, especially when using a NFS based rootfs. So lets
change this timeout to a more defensive value of 30 seconds.
Also we now call the hw_watchdog_init() function so that we override
the value already configured from the Preloader.
Remove the now unnecessary clocking info from the SoCFPGA
config header. As this info in now used directly in the SPI driver
itself.
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Vince Bridgers <vbridger@altera.com>
Enable support for the DW master SPI controller in the config header
for the SoCFPGA. This controller can only be enabled, if DT support
is enabled.
With this driver enabled for SoCFPGA, access to SPI NOR flash is
supported.
The configuration (page size, timing info) will be taken from the
DT. See socrates as an example.
This QSPI supports depends on DT. So QSPI is only enabled if
CONFIG_OF_CONTROL is defined (see socfpga_socrates_defconfig).
Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Some (not all) of ARMv7 boards define CONFIG_ARMV7, which is useless.
Besides, it is never referenced.
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Add example of an USB UDC configuration with DFU and UMS.
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
Add example config file entry for the Altera SPI controller. This SPI
controller can also, under special conditions, be used to operate the
EPCS/EPCQ SPI NOR.
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
This patch adds I2C support for the SoCFPGA. Using the designware I2C
controller driver. It supports all 4 I2C busses on the SoCFPGA.
The designware I2C driver has now been converted to the
CONFIG_SYS_I2C framework. So lets enable it on SoCFPGA.
Tested on SoCrates.
