path: root/include/configs/socfpga_common.h
2015-05-07ARM: socfpga: abolish CONFIG_SOCFPGAMasahiro Yamada
Replace CONFIG_SOCFPGA with CONFIG_ARCH_SOCFPGA. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-07ARM: socfpga: move SoC sources to mach-socfpgaMasahiro Yamada
Our recent trend is to collect SoC files into arch/arm/mach-(SOC). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-04-21arm: socfpga: spl: Adjust the SYS_INIT_RAM_SIZE to have room for the spl mallocDinh Nguyen
We need to adjust the SYS_INIT_RAM_SIZE to have room for the SPL_MALLOC_SIZE. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-04-21arm: socfpga: spl: add CONFIG_SPL_STACK to socfpga_common.hDinh Nguyen
2015-04-21arm: socfpga: spl: Add CONFIG_SPL_MAX_SIZE to be 64KBDinh Nguyen
The Cyclone5 SoCFPGA has 64KB of OCRAM for SPL use. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-03-04arm: socfpga: Zap board_early_init_f()Marek Vasut
Zap this unused empty function, no point in having it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@opensource.altera.com> Acked-by: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Pavel Machek <pavel@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Cc: Vince Bridgers <vbridger@opensource.altera.com>
2015-03-04arm: socfpga: Zap checkboard()Marek Vasut
Since all boards now have a DT, instead of hard-coding the board name into the U-Boot binary, read the board name from DT "model" property. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@opensource.altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Stefan Roese <sr@denx.de> Cc: Vince Bridgers <vbridger@opensource.altera.com>
2015-02-12dm: socfpga: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-21arm: socfpga: Change watchdog timeoutStefan Roese
The current current watchdog timeout of 12 seconds is a bit small for booting into Linux, especially when using a NFS based rootfs. So lets change this timeout to a more defensive value of 30 seconds. Also we now call the hw_watchdog_init() function so that we override the value already configured from the Preloader. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Vince Bridgers <vbridger@opensource.altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Chin Liang See <clsee@altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Pavel Machek <pavel@denx.de>
2014-12-06arm: socfpga: DW_SPI: Remove clock info from config headerStefan Roese
Remove the now unnecessary clocking info from the SoCFPGA config header. As this info in now used directly in the SPI driver itself. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Vince Bridgers <vbridger@altera.com> Cc: Marek Vasut <marex@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-12-06arm: socfpga: Add Designware (DW) SPI support to config headerStefan Roese
Enable support for the DW master SPI controller in the config header for the SoCFPGA. This controller can only be enabled, if DT support is enabled. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Vince Bridgers <vbridger@altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Pavel Machek <pavel@denx.de>
2014-12-06arm: socfpga: Add Cadence QSPI support to config headerStefan Roese
With this driver enabled for SoCFPGA, access to SPI NOR flash is supported. The configuration (page size, timing info) will be taken from the DT. See socrates as an example. This QSPI supports depends on DT. So QSPI is only enabled if CONFIG_OF_CONTROL is defined (see socfpga_socrates_defconfig). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Vince Bridgers <vbridger@altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Pavel Machek <pavel@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-11-20ARM: remove CONFIG_ARMV7 definesMasahiro Yamada
Some (not all) of ARMv7 boards define CONFIG_ARMV7, which is useless. Besides, it is never referenced. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-11Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2014-11-07arm: socfpga: Add example UDC configMarek Vasut
Add example of an USB UDC configuration with DFU and UMS. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Vince Bridgers <vbridger@altera.com> Acked-by: Pavel Machek <pavel@denx.de> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2014-10-31arm: socfpga: Add example config entry for EPCS/EPCQ SPIMarek Vasut
Add example config file entry for the Altera SPI controller. This SPI controller can also, under special conditions, be used to operate the EPCS/EPCQ SPI NOR. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Vince Bridgers <vbridger@altera.com> Cc: Pavel Machek <pavel@denx.de> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-10-30arm: socfpga: Add I2C support to SoCFPGAStefan Roese
This patch adds I2C support for the SoCFPGA. Using the designware I2C controller driver. It supports all 4 I2C busses on the SoCFPGA. The designware I2C driver has now been converted to the CONFIG_SYS_I2C framework. So lets enable it on SoCFPGA. Tested on SoCrates. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Vince Bridgers <vbridger@altera.com> Cc: Pavel Machek <pavel@denx.de> Cc: Heiko Schocher <hs@denx.de>
2014-10-27arm: socfpga: config: Add USB support exampleMarek Vasut
Add example configuration stub for the DWC2 USB controller. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Vince Bridgers <vbridger@altera.com> Cc: Pavel Machek <pavel@denx.de>
2014-10-27arm: socfpga: Zap spl.h and ad-hoc related symsMarek Vasut
Switch to the common spl.h file and zap the arch/spl.h . Since the arch/spl.h contained various ad-hoc symbols, zap those symbols as well and rework the board configuration a little so it doesn't depend on them. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Vince Bridgers <vbridger@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-27arm: socfpga: Move code from misc_init_r() to arch_early_init_r()Marek Vasut
Move this initialization code to proper place. The misc_init_r() function is called way too late and the platform initialization code should be executed much earlier. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Vince Bridgers <vbridger@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: Split SoCFPGA configurationPavel Machek
Split the SoCFPGA configuration into SoC-specific part which is common for all boards (socfpga_cyclone5_common.h) and a board specific part. There is currently only one board, which is the generic SoCFPGA board (socfpga_cyclone5.h), but there are more to come. This is necessary due to various features of the boards, which unfortunatelly cannot be autodetected. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
