These boards will now use the ksz90x1 driver instead of the mess in
ksz8xxx. This change is needed before the two drivers can be fully
separated.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Now that these symbols are in Kconfig, migrate all users. Use imply on
a number of platforms that default to having this enabled. As part of
this we must migrate some straglers for CMD_FAT and DOS_PARTITION.
This removes the default environment from the A5 socdk headers
and instead uses the common environment provided in
socfpga_common.h which now uses distro boot.
Add support to boot from the custom a2 type partition.
Change default devicetree name to match devicetree name in
upstream kernel source.
Signed-off-by: Dalon Westergreen <dwesterg@gmail.com>
Changes in v3:
- Fix small typo in defconfig, missing "C"
Changes in v2:
- Remove unneeded CONFIG_BOOTFILE
- Fix dtb name
a5config test
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There is an incorrect space after loadaddr= in the extra environment,
so drop it.
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Chin Liang See <clsee@altera.com>
Update the qspiboot console command to use UBIFS instead
of old jffs2 file system.
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinh.linux@gmail.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Stefan Roese <sr@denx.de>
Enabling qspiload command which will load the kernel
image and dtb from UBIFS within MTD partition labeled
UBI.
Enabling ubiload command to load kernel image and
device tree from mtd part labeled "UBI". ubiload
command will search the file from directory /boot.
Remove the duplication of SDMMC environment configuration
from each boards' configuration header file into
socfpga_common.h
We already have the CONFIG_SYS_BOARD variable, which defines the name
of the board. The value in CONFIG_HOSTNAME is exactly the same and is
thus just a duplicity, so switch it to reuse CONFIG_SYS_BOARD .
We already have the CONFIG_SYS_VENDOR variable, which defines the
manufacturer of the board. The value in CONFIG_G_DNL_MANUFACTURER
is just a duplicity, so switch it to reuse CONFIG_SYS_VENDOR .
This patch adds the necessary OF alias for the UDC node, which let's
the code locate the DWC2 UDC base address in OF instead of hard-coding
it into the U-Boot binary. The code is adjusted to use the address from
OF instead of the hard-coded one. Finally, the hard-coded address is
removed and USB DM support is enabled.
Cc: Lukasz Majewski <l.majewski@majess.pl>
Cc: Lukasz Majewski <l.majewski@samsung.com>
The Micrel PHY configuration is now done from OF, so hard-coding
the configuration into the board file is no longer necessary.
Remove fsloadcmd / ext2load as we are using load command
which use the corresponding latest file system command.
When adding support for the Arria10 platform, we're going to name the file
base_addr_a10.h, so to be systematic about it, rename the socfpga_base_addr.h
to be base_addr_ac5.h for the Arria5 and Cyclone5 platform.
Suggested-by: Marek Vasut <marex@denx.de>
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Add CMD_GPIO to Kconfig and run tools/moveconfig.py .
Enable the able to save the environment variables when SD/MMC is used.
Rename the socfpga_cyclone5.h to socfpga_cyclone5_socdk.h, and
socfpga_arria.h to socfpga_arria5_socdk.h. This matches the other SoCFPGA
board config files.
