path: root/include/configs/snow.h
2015-08-05exynos: config: Move common options to the common headers and tidy upSimon Glass
Many options are duplicated on the exynos5 boards. Move these to the common files. Also some options are not used so can be removed. Tidy this up to make the files easier to maintain. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-08-05exynos: Enable new features for exynos5 boardsSimon Glass
Enable PMICs, regulators and the like so that new drivers will be made available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: usb: exynos: Enable both USB ports on snowSimon Glass
Switch snow over to use both EHCI and XHCI at the same time. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18exynos: cros_ec: Drop unnecessary initSimon Glass
Since driver model will probe the EC when it is first used, we do not need to init it explicitly. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-19dm: cros_ec: Convert to KconfigSimon Glass
Since both I2C and SPI are converted to Kconfig, we can convert cros_ec to Kconfig for these buses. LPC will need to wait until driver mode PCI is available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: cros_ec: Convert cros_ec_i2c over to driver modelSimon Glass
Move this driver to use driver model and update the snow configuration to match. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-08config: Move arndale to use common exynos5250 fileSimon Glass
Most of the arndale features are common with other exynos5250 boards. To permit easier addition of driver model support, use the common file. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: config: Move cros_ec and tps65090 out of smdk boardsSimon Glass
These boards do not in fact have a Chrome OS EC, nor a TPS565090 PMIC, so move the settings into a separate common file to be used by those that need it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: Move common exynos settings into a common fileSimon Glass
Since exynos4 and exyno5 share many settings, we should move these into a common file to avoid duplication. In effect the changes are that all exynos boards now have EXT4 and FAT write support. This affects exynos5250 and exynos5420 which previously did not. This also disables the ext2 commands which are equivalent to ext4 anyway. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: Rename -dt config files to -commonSimon Glass
We want exynos5250-dt.h to be a board which can support any exynos5250 device. This matches the naming used by Linux. As a first step, rename the existing -dt files to -common to make it clear they are common files, and not specific boards. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-05-13Exynos5: config: Enable FITAkshay Saraswat
Adding two configs: * CONFIG_FIT - Enable FIT image support. * CONFIG_FIT_BEST_MATCH - Enable fetching correct DTB from FIT image by comparing compatibles. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-12EXYNOS5: Snow: Add a configuration fileRajeshwari Shinde
This patch adds the configuration file for Snow Board and defines the same in boards.cfg. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
