path: root/include/configs/sniper.h
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_VBUS_DRAW to KconfigSam Protsenko
The description was borrowed from kernel. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use 2 mA (as minimal allowed by Kconfig). Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-01sniper: Include explicit serial baudrate on bootargsPaul Kocialkowski
This makes the baudrate for the kernel command line explicit. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-29sniper: Various minor cleanups, missing Kconfig configs and reorganisationPaul Kocialkowski
This introduces some minor cleanups, regarding aspects such as board name, code and headers organization as well as deprecated and missing config options. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-08sniper: Drop references to P970Paul Kocialkowski
There are various different boards with the same hardware sold as LG Optimus Black, such as P970, P970g and KU5900. Since this port is functional for all variants, it doesn't make sense to keep references to P970. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-13sniper: Various boot-related env settings, devicetree supportPaul Kocialkowski
This adds various env settings for more flexible boot possibilities, including devicetree support and distro defaults config. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-11-21ns16550: zap CONFIG_NS16550_SERIALThomas Chou
Zap CONFIG_NS16550_SERIAL, as the unification of ns16550 drivers is completed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-21ns16550: unify serial_omapThomas Chou
Unify serial_omap, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-12sniper: Fastboot supportPaul Kocialkowski
This adds support for the fastboot USB gadget, including flashing to the internal MMC and reboot to bootloader or not. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Update to use Kconfig for MUSB] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12sniper: Pass serial number through ATAGPaul Kocialkowski
Now that the serial number is correctly defined, we can pass it to the kernel using the (legacy) ATAG method. It will be automatically passed via device-tree when enabled. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-12sniper: OMAP3 reboot mode supportPaul Kocialkowski
This adds support for the omap3 reboot mode mechanism and exports the reboot mode via an environment variable, that is used in the boot command to make it possible to boot from the recovery partition. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-12LG Optimus Black (P970) codename sniper supportPaul Kocialkowski
The LG Optimus Black (P970) codename sniper is a smartphone that was designed and manufactured by LG Electronics (LGE) and released back in 2011. It is using an OMAP3630 SoC GP version, which allows running U-Boot and the U-Boot SPL from the ground up. This port is aimed at running an Android version such as Replicant, the fully free Android distribution. However, support for upstream Linux with device-tree and common GNU/Linux distros boot commands could be added in the future. For more information about the journey to freeing this device, please read the series of blog posts at: http://code.paulk.fr/article20/a-hacker-s-journey-freeing-a-phone-from-the-ground-up-first-part Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Add CONFIG_OF_SUPPORT] Signed-off-by: Tom Rini <trini@konsulko.com>
