path: root/include/configs/smdkv310.h
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-08ARM: SAMSUNG: support sdhci controllerJaehoon Chung
To support sdhci controller, remove the CONFIG_S5P_MMC.. Instead, use the CONFIG_S5P_SDHCI/CONFIG_SDHCI. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Lei Wen<leiwen@marvell.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2011-12-09S5PC2XX: Rename S5pc2XX to exynosChander Kashyap
As per new naming convention for Samsung SoC's, all Cortex-A9 and Cortex-A15 based SoC's will be classified under the name Exynos. Cortex-A9 and Cortex-A15 based SoC's will be sub-classified as Exynos4 and Exynos5 respectively. In order to better adapt and reuse code across various upcoming Samsung Exynos based boards, all uses of s5pc210 prefix/suffix/directory-names are renamed in this patch. s5pc210 is renamed as exynos4210 and S5PC210/s5pc210 suffix/prefix are renamed as exynos4/EXYNOS4. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-11-03smdkv310: use macro for mmc data read function addressChander Kashyap
board/samsung/smdkv310/mmc_boot.c: Removed the typedef for "mmc data read API (copy_sd_mmc_to_mem)" as it is used only once and replaced hard-coded API address value by macro. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-11-03smdkv310: use spl framework for mmc splChander Kashyap
smdkv310 board was using mmc_spl framework for mmc spl support. This patch migrates the framework from mmc_spl to spl. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-11-03SMDKV310: Initialize board id using CONFIG_MACH_TYPEChander Kashyap
Use CONFIG_MACH_TYPE generic macro to initialize board id. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-08-04SMDKV310: Enable device tree supportThomas Abraham
Enable passing a flattened device tree to the kernel. Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
2011-08-04Removed unused define, CONFIG_ARMV7.Christopher Harvey
Signed-off-by: Christopher Harvey <charvey@matrox.com>
2011-05-26ARMV7: Add support for Samsung SMDKV310 BoardChander Kashyap
SMDKV310 board is based on Samsung S5PV310 SOC. This SOC is very much similar to S5PC210. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
