path: root/include/configs/smdk5420.h
2022-12-22global: Remove unused CONFIG symbolsTom Rini
This removes the following unreferenced CONFIG symbols: CONFIG_FDTADDR CONFIG_FDTFILE CONFIG_FLASH_SECTOR_SIZE CONFIG_FSL_CPLD CONFIG_HDMI_ENCODER_I2C_ADDR CONFIG_I2C_MVTWSI CONFIG_I2C_RTC_ADDR CONFIG_IRAM_END CONFIG_IRAM_SIZE CONFIG_KSNET_MDIO_PHY_CONFIG_ENABLE CONFIG_L1_INIT_RAM CONFIG_MACB_SEARCH_PHY CONFIG_MIU_2BIT_21_7_INTERLEAVED CONFIG_MTD_NAND_VERIFY_WRITE CONFIG_MVGBE_PORTS CONFIG_NETDEV CONFIG_NUM_DSP_CPUS CONFIG_PHY_BASE_ADR CONFIG_PHY_INTERFACE_MODE CONFIG_PSRAM_SCFG CONFIG_RAMBOOT_SPIFLASH CONFIG_RAMBOOT_TEXT_BASE CONFIG_RD_LVL CONFIG_ROCKCHIP_SDHCI_MAX_FREQ CONFIG_SETUP_INITRD_TAG CONFIG_SH_QSPI_BASE CONFIG_SMDK5420 CONFIG_SOCRATES CONFIG_SPI_ADDR CONFIG_SPI_FLASH_QUAD CONFIG_SPI_FLASH_SIZE CONFIG_SPI_HALF_DUPLEX CONFIG_SPI_N25Q256A_RESET CONFIG_TEGRA_SLINK_CTRLS CONFIG_TPM_TIS_BASE_ADDRESS CONFIG_UBOOT_SECTOR_COUNT CONFIG_UBOOT_SECTOR_START CONFIG_VAR_SIZE_SPL CONFIG_VERY_BIG_RAM And also: BL1_SIZE PHY_NO RESERVE_BLOCK_SIZE Signed-off-by: Tom Rini <trini@konsulko.com>
2022-12-05global: Move remaining CONFIG_SYS_SDRAM_* to CFG_SYS_SDRAM_*Tom Rini
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_SDRAM namespace do not easily transition to Kconfig. In many cases they likely should come from the device tree instead. Move these out of CONFIG namespace and in to CFG namespace. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-07-07Convert CONFIG_USB_XHCI_EXYNOS et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_USB_XHCI_EXYNOS CONFIG_USB_EHCI_EXYNOS Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-28video: Migrate exynos display options to KconfigTom Rini
Following how it's done for the majority of drivers, add a new VIDEO_EXYNOS option and Kconfig file under drivers/video/exynos and list the current options there. Cc: Anatolij Gustschin <agust@denx.de> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2022-06-06Migrate CUSTOM_SYS_INIT_SP_ADDR to Kconfig using system-constants.hTom Rini
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR - Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack pointer directly, otherwise we use the common calculation. - On some platforms that were using the standard calculation but did not set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them. - On a small number of platforms that were not subtracting GENERATED_GBL_DATA_SIZE do so now via the standard calculation. - CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most board config header files. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-03-03Convert CONFIG_BOARD_COMMON to KconfigTom Rini
This converts the following to Kconfig: CONFIG_BOARD_COMMON Signed-off-by: Tom Rini <trini@konsulko.com>
2021-12-05Convert CONFIG_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org>
2020-10-15treewide: configs: get rid of unused CONFIG_DEFAULT_CONSOLEAndre Heider
These are all unused. Signed-off-by: Andre Heider <a.heider@gmail.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Acked-by: Krzysztof Kozlowski <krzk@kernel.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2018-08-17Removed unused references to CONFIG_SERIALxAdam Ford
After creating CONS_INDEX and migrating a bunch of boards to it, there are a bunch of defined references to CONFIG_SERIALx which are not referenced in any C code or #ifdef, so they can now be removed Signed-off-by: Adam Ford <aford173@gmail.com>
2016-06-06Merge http://git.denx.de/u-boot-samsungTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/peach-pi_defconfig configs/peach-pit_defconfig
2016-06-04usb: move CONFIG_USB_XHCI to Kconfig with renamingMasahiro Yamada
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it into CONFIG_USB_XHCI_HCD. As commented in the help of "config USB_XHCI" entry, this has been a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI have been unified in favor of the former. Note: Some boards define CONFIG_USB_XHCI in their headers without CONFIG_USB, which does not meet the "depends on" in Kconfig. I added CONFIG_USB=y for those boards when converting. Otherwise, they would fail to build. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-05-25exynos: Disable LCD display for boards we can't convertSimon Glass
Some boards have the LCD enabled but I cannot test operation for the driver model conversion. Disable the LCD on these to avoid build errors. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-08-05exynos: config: Move common options to the common headers and tidy upSimon Glass
Many options are duplicated on the exynos5 boards. Move these to the common files. Also some options are not used so can be removed. Tidy this up to make the files easier to maintain. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2014-12-30Exynos: Move down common USB configurationSjoerd Simons
USB is a pretty common feature on exynos 5 board, so it seems sensible to configure it directly from exynos5-common. As a side-effect this makes USB available from u-boot on exynos 5420 based boards. While there enable support for common USB ethernet cards to make it more likely the default config allows booting for network and enable XHCI on SMDK5420 which has it defined in the dts but not in its config. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-12-22config: exynos5420: move non common configs to specific board filesHyungwon Hwang
The media for boot and environment is a board-specific feature, not a processor-specific. This is same to console port number and some other addresses. This patch moves the that kinds of configs to each board-specific files from the common config file for Exynos5420. Signed-off-by: Hyungwon Hwang <human.hwang@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17Config: Exynos5420: Refactor SDRAM Bank and SizeAkshay Saraswat
Since, not every board may have all memory channels configured and all available banks of DMC used, we wish to refactor configs for Memory Bank size and numbers as per board memory config. For Example, Peach-Pit has 2GB memory and will be using only 4 banks but Peach-Pi has 3.5GB memory and will be using all 7 available SDRAM banks. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08config: Move arndale to use common exynos5250 fileSimon Glass
Most of the arndale features are common with other exynos5250 boards. To permit easier addition of driver model support, use the common file. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: Move common smdk5420 things to common fileSimon Glass
A few things are common but are not in the common file. Fix this and rename the file to fit with the other exynos*-common files. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: Rename -dt config files to -commonSimon Glass
We want exynos5250-dt.h to be a board which can support any exynos5250 device. This matches the naming used by Linux. As a first step, rename the existing -dt files to -common to make it clear they are common files, and not specific boards. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-06-23Exynos5420: Introduce support for the Peach-Pit boardAkshay Saraswat
While the Exynos5420 chip is used in both Smdk5420 and in the Peach-Pit line of devices, there could be other boards using the same chip, so a common configuration file is being added (exynos5420.h) as well as two common device tree files (exynos54xx.dtsi & exynos5420.dtsi). The peach board as declared in boards.cfg is a copy of smdk5420 declaration. The configuration files are similar, but define different default device trees, console serial ports and prompts. The device tree files for smdk5420 and peach-pit inherit from the same common file. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-13Exynos5: config: Enable FITAkshay Saraswat
Adding two configs: * CONFIG_FIT - Enable FIT image support. * CONFIG_FIT_BEST_MATCH - Enable fetching correct DTB from FIT image by comparing compatibles. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-24arm: delete unused macro CONFIG_ARCH_DEVICE_TREEMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Rajeshwari Birje <rajeshwari.s@samsung.com> Cc: Inderpal Singh <inderpal.singh@linaro.org>
2013-12-30SPL: EXYNOS: Prepare for variable size SPL supportRajeshwari Birje
When variable size SPL is used, the BL1 expects the SPL to be encapsulated differently: instead of putting the checksum at a fixed offset in the SPL blob, prepend the blob with a header including the size and the checksum. The enhancements include - adding a command line option, '--vs' to indicate the need for the variable size encapsulation - padding the fixed size encapsulated blob with 0xff instead of random memory contents - do not silently truncate the input file, report error instead - no need to explicitly closing files/freeing memory, this all happens on exit; removing cleanups it makes code clearer - profuse commenting - modify Makefile to allow enabling the new feature per board Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-30Config: Add initial config for SMDK5420Rajeshwari Birje
Adding initial config for SMDK5420 to build and boot U-Boot over Exynos based SMDK5420. Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
