These are all unused.
Signed-off-by: Andre Heider <a.heider@gmail.com>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
After creating CONS_INDEX and migrating a bunch of boards to it,
there are a bunch of defined references to CONFIG_SERIALx which
are not referenced in any C code or #ifdef, so they can now be
removed
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
CONFIG_LCD
Reviewed-by: Jagan Teki <jteki@openedev.com>
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
[trini: Update configs, add some default to sunxi Kconfig]
configs/peach-pi_defconfig
configs/peach-pit_defconfig
Move CONFIG_USB_XHCI to defconfig files for all boards, renaming it
into CONFIG_USB_XHCI_HCD.
As commented in the help of "config USB_XHCI" entry, this has been
a TODO for a long time; now CONFIG_USB_XHCI_HCD and CONFIG_USB_XHCI
have been unified in favor of the former.
Note:
Some boards define CONFIG_USB_XHCI in their headers without
CONFIG_USB, which does not meet the "depends on" in Kconfig.
I added CONFIG_USB=y for those boards when converting.
Otherwise, they would fail to build.
Some boards have the LCD enabled but I cannot test operation for the driver
model conversion. Disable the LCD on these to avoid build errors.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
Many options are duplicated on the exynos5 boards. Move these to the common
files. Also some options are not used so can be removed.
Tidy this up to make the files easier to maintain.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
USB is a pretty common feature on exynos 5 board, so it seems sensible
to configure it directly from exynos5-common. As a side-effect this
makes USB available from u-boot on exynos 5420 based boards.
While there enable support for common USB ethernet cards to make it more
likely the default config allows booting for network and enable XHCI on
SMDK5420 which has it defined in the dts but not in its config.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
The media for boot and environment is a board-specific feature, not a
processor-specific. This is same to console port number and some
other addresses. This patch moves the that kinds of configs to each
board-specific files from the common config file for Exynos5420.
Signed-off-by: Hyungwon Hwang <human.hwang@samsung.com>
Tested-by: Kevin Hilman <khilman@linaro.org>
Since, not every board may have all memory channels configured
and all available banks of DMC used, we wish to refactor configs
for Memory Bank size and numbers as per board memory config.
For Example, Peach-Pit has 2GB memory and will be using only 4 banks
but Peach-Pi has 3.5GB memory and will be using all 7 available
SDRAM banks.
Signed-off-by: Akshay Saraswat <akshay.s@samsung.com>
Most of the arndale features are common with other exynos5250 boards. To
permit easier addition of driver model support, use the common file.
A few things are common but are not in the common file. Fix this and
rename the file to fit with the other exynos*-common files.
We want exynos5250-dt.h to be a board which can support any exynos5250
device. This matches the naming used by Linux. As a first step, rename
the existing -dt files to -common to make it clear they are common files,
and not specific boards.
This option specifies the default Device Tree used for the run-time
configuration of U-Boot.
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Michal Simek <michal.simek@xilinx.com>
While the Exynos5420 chip is used in both Smdk5420 and in the Peach-Pit
line of devices, there could be other boards using the same chip, so a
common configuration file is being added (exynos5420.h) as well
as two common device tree files (exynos54xx.dtsi & exynos5420.dtsi).
The peach board as declared in boards.cfg is a copy of smdk5420
declaration. The configuration files are similar, but define different
default device trees, console serial ports and prompts.
The device tree files for smdk5420 and peach-pit inherit from the same
common file.
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Adding two configs:
* CONFIG_FIT - Enable FIT image support.
* CONFIG_FIT_BEST_MATCH - Enable fetching correct DTB from
FIT image by comparing compatibles.
Cc: Tom Warren <twarren@nvidia.com>
Cc: Rajeshwari Birje <rajeshwari.s@samsung.com>
Cc: Inderpal Singh <inderpal.singh@linaro.org>
When variable size SPL is used, the BL1 expects the SPL to be
encapsulated differently: instead of putting the checksum at a fixed
offset in the SPL blob, prepend the blob with a header including the
size and the checksum.
The enhancements include
- adding a command line option, '--vs' to indicate the need for the
variable size encapsulation
- padding the fixed size encapsulated blob with 0xff instead of random
memory contents
- do not silently truncate the input file, report error instead
- no need to explicitly closing files/freeing memory, this all happens
on exit; removing cleanups it makes code clearer
- profuse commenting
- modify Makefile to allow enabling the new feature per board
Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com>
Adding initial config for SMDK5420 to build and boot U-Boot
over Exynos based SMDK5420.
