path: root/include/configs/smdk5250.h
2016-05-25exynos: Disable LCD display for boards we can't convertSimon Glass
Some boards have the LCD enabled but I cannot test operation for the driver model conversion. Disable the LCD on these to avoid build errors. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-08-05exynos: config: Move common options to the common headers and tidy upSimon Glass
Many options are duplicated on the exynos5 boards. Move these to the common files. Also some options are not used so can be removed. Tidy this up to make the files easier to maintain. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-08-05exynos: Enable new features for exynos5 boardsSimon Glass
Enable PMICs, regulators and the like so that new drivers will be made available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18exynos: cros_ec: Drop unnecessary initSimon Glass
Since driver model will probe the EC when it is first used, we do not need to init it explicitly. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29smdk5250: config: enable max77686 driver supportPrzemyslaw Marczak
This commit enable support for the above driver, which was disabled in common config. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08config: Move arndale to use common exynos5250 fileSimon Glass
Most of the arndale features are common with other exynos5250 boards. To permit easier addition of driver model support, use the common file. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: Move common exynos settings into a common fileSimon Glass
Since exynos4 and exyno5 share many settings, we should move these into a common file to avoid duplication. In effect the changes are that all exynos boards now have EXT4 and FAT write support. This affects exynos5250 and exynos5420 which previously did not. This also disables the ext2 commands which are equivalent to ext4 anyway. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: Rename -dt config files to -commonSimon Glass
We want exynos5250-dt.h to be a board which can support any exynos5250 device. This matches the naming used by Linux. As a first step, rename the existing -dt files to -common to make it clear they are common files, and not specific boards. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-05-13Exynos5: config: Enable FITAkshay Saraswat
Adding two configs: * CONFIG_FIT - Enable FIT image support. * CONFIG_FIT_BEST_MATCH - Enable fetching correct DTB from FIT image by comparing compatibles. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-26SMDK5250: config: Add configuration file for SMDK5250 boardHatim RV
Add the configuration file for exynos5250 based SMDK5250 board. Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-26exynos5: config: Rename the smdk5250.h to exynos5250-dt.hHatim RV
Create a common configuration file for all exynos5250 based boards. Going forward we will be using DT based driver discovery for all the boards based on Exynos5. The different boards added will have there own config.h files which internally will include this file and specify their specific DT files. Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-22Merge samsung, imx, tegra into u-boot-arm/masterAlbert ARIBAUD
This commit merges branches from samsung, imx and tegra meant to fix merge issues between u-boot/master and u-boot-arm/master, as well as a few manual merge fixes.
2012-12-19Merge remote-tracking branch 'u-boot/master' into u-boot-arm-mergedAllen Martin
Conflicts: README arch/arm/cpu/armv7/exynos/clock.c board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-11exynos: Enable hashing functions and EDID for smdk5250Simon Glass
Enable SHA1/SHA256 hashing and the hash command. Also enable EDID support for reading from an LCD. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-11SMDK5250: Enable pmic MAX77686Rajeshwari Shinde
Enabled pmic MAX77686 for SMDK5250. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-15EXYNOS5: Enable SPI booting.Rajeshwari Shinde
This patch enables SPI Booting for EXYNOS5 Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-15EXYNOS5: Enable SPIHatim RV
This patch enables SPI driver for EXYNOS5. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-15SMDK5250: Enable SoundRajeshwari Shinde
This patch enables sound support for EXYNOS5 Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Chander Kashyap <chander.kashyap@linaro.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-15SMDK5250: Config: Enable MAX77686 pmic chipRajeshwari Shinde
This patch enables MAX77686 pmic chip for SMDK5250. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-15Exynos5250: Enable PXE SupportChander Kashyap
Add PXE support for the Exynos5250. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01SMDK5250: Enable UART and MMC for Exynos5250 Rev 1.0Rajeshwari Shinde
This patch sets UART3 and MMC channle 0 for Exynos5250 Rev 1.0 Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01SMDK5250: Add smdk5250-uboot-spl.ldsRajeshwari Shinde
Default spl/u-boot-spl.lds created by spl/Makefile resolves the spl text load addr to 0x0. As 0x0 belongs to iROM addr so Global variables can not be used. Adding specific smdk5250-uboot-spl.lds makes possible to use Global Variables in spl. Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-07-31CONFIG: SMDK5250: I2C: Enable I2CRajeshwari Shinde
This enables I2C support on smdk5250. Pinmux setting moved to board file to avoid repeated setting of gpio lines. Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-07-09CONFIG: EXYNOS5: USB: Enable USB 2.0 on smdk5250Rajeshwari Shinde
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-08ARM: SAMSUNG: support sdhci controllerJaehoon Chung
To support sdhci controller, remove the CONFIG_S5P_MMC.. Instead, use the CONFIG_S5P_SDHCI/CONFIG_SDHCI. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Lei Wen<leiwen@marvell.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12SMDK5250: Add ethernet supportChander Kashyap
This patch enable support for SMC911X based ethernet device. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12EXYNOS: SMDK5250: Add MMC SPL supportChander Kashyap
This patch adds support for MMC SPL booting. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12EXYNOS: Add SMDK5250 board supportChander Kashyap
SMDK5250 board is based on Samsungs EXYNOS5250 SoC. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
