path: root/include/configs/smartweb.h
2017-01-14arm: Remove unregister MACH_TYPE_xxx usesTom Rini
Before we can sync with the latest mach-types.h file from the Linux Kernel we need to remove some instances of MACH_TYPE_xxx from our sources. As these values have been removed from the canonical upstream source we should not be using them either, so drop. Cc: Tom Warren <twarren@nvidia.com> Cc: Lucas Stach <dev@lynxeye.de> Cc: Luka Perkov <luka@openwrt.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Heiko Schocher <hs@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Lucile Quirion <lucile.quirion@savoirfairelinux.com> Cc: Matthias Weisser <weisserm@arcor.de> Cc: Suriyan Ramasami <suriyan.r@gmail.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Nick Thompson <nick.thompson@gefanuc.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Erik van Luijk <evanluijk@interact.nl> Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-08-15net: macb: Fix build error for CONFIG_DM_ETH enabledWenyou Yang
Use the right phy_connect() prototype for CONFIGF_DM_ETH. Support to get the phy interface from dt and set GMAC_UR. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-06-26arm: at91: smartweb: add DM and DTS supportHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> [rebased on current ToT] Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-20Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Conflicts: configs/bcm28155_ap_defconfig configs/dra72_evm_defconfig configs/dra74_evm_defconfig configs/ma5d4evk_defconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_VBUS_DRAW to KconfigSam Protsenko
The description was borrowed from kernel. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use 2 mA (as minimal allowed by Kconfig). Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-18cmd: fdt: Use separate CMD_FDT Kconfig entry instead of OF_LIBFDTMichal Simek
Create CMD_FDT Kconfig entry to have an option to disable fdt command which is not required for small configuration which requires libfdt only. Enable it by default for all targets which enables OF_LIBFDT. Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fixup flea3/sandbox/id8313/siemens-am33xx/smartweb] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-18siemens,at91: enable features for smartwebMatthias Michel
New features for smartweb: * switch to hush command parser * change autoboot stop to <ESC><ESC> * allow to write ethaddr Signed-off-by: Matthias Michel <matthias.michel@siemens.com> Reviewed-by: Samuel Egli <samuel.egli@siemens.com> Cc: Roger Meier <r.meier@siemens.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-10-01arm, at91: small updates for the smartweb boardHeiko Schocher
- add CONFIG_BOOT_RETRY_TIME to 30 - fex LED colors - fix button pressed combination - add CONFIG_USB_HOST_ETHER CONFIG_USB_ETHER_ASIX CONFIG_USB_ETHER_MCS7830 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Matthias Michel <matthias.michel@siemens.com>
2015-09-11at91, taurus, smartweb: add dfu supportHeiko Schocher
[root@pollux dfu-util]# ./src/dfu-util -l dfu-util 0.8 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2014 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to dfu-util@lists.gnumonks.org Found DFU: [0908:02d2] ver=0212, devnum=119, cfg=1, intf=0, alt=0, name="Linux", serial="UNKNOWN" [root@pollux dfu-util]# Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2015-08-12arm, at91: support for sam9260 based smartweb boardHeiko Schocher
add support for the at91sam9260 based board smartweb from siemens. SPL is used without serial support, as this SoC has only 4k sram for running SPL. Here a U-Boot bootlog: RomBOOT > U-Boot 2015.07-rc2-00109-g4ae828c (Jun 15 2015 - 09:31:16 +0200) CPU: AT91SAM9260 Crystal frequency: 18.432 MHz CPU clock : 198.656 MHz Master clock : 99.328 MHz Watchdog enabled DRAM: 64 MiB WARNING: Caches not enabled NAND: 256 MiB In: serial Out: serial Err: serial Net: macb0 Hit any key to stop autoboot: 0 U-Boot> Signed-off-by: Heiko Schocher <hs@denx.de>
