path: root/include/configs/siemens-am33x-common.h
2019-04-19configs: Migrate USB_MUSB_DISABLE_BULK_COMBINE_SPLIT to KconfigAlex Kiernan
Migrate support for disable MUSB bulk split/combine to Kconfig Green Travis build: https://travis-ci.org/akiernan/u-boot/builds/519101867 Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-08-17Removed unused references to CONFIG_SERIALxAdam Ford
After creating CONS_INDEX and migrating a bunch of boards to it, there are a bunch of defined references to CONFIG_SERIALx which are not referenced in any C code or #ifdef, so they can now be removed Signed-off-by: Adam Ford <aford173@gmail.com>
2018-08-17Migrate bootlimit to KconfigAlex Kiernan
Migrate boards which set bootlimit in the environment to Kconfig. We exclude gurnard_defconfig which includes a bootlimit=, but doesn't set CONFIG_BOOTCOUNT_LIMIT, so we'd fail to include a bootlimit setting if we migrated it. display5_defconfig and display5_factory_defconfig share a SYS_CONFIG_NAME, but only display5_defconfig enables CONFIG_BOOTCOUNT_LIMIT, so we fail to set bootlimit= in display5_factory_defconfig. This is okay because the display5_factory_defconfig doesn't need to have it set, as it is only meant to prepare the board in the factory. Environment changes for all modified configs as seen from buildman: boards.cfg is up to date. Nothing to do. Summary of 3 commits for 32 boards (8 threads, 1 job per thread) 01: Merge git://git.denx.de/u-boot-x86 arm: + draco etamin rastaban pxm2 display5 thuban rut 02: Add BOOTCOUNT_BOOTLIMIT to set reboot limit 03: Migrate bootlimit to Kconfig - display5_factory: bootlimit=3 Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08Migrate CONFIG_DRIVER_TI_CPSW to KconfigAlex Kiernan
This converts CONFIG_DRIVER_TI_CPSW to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-24Convert CONFIG_BOOTCOUNT_ENV to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_BOOTCOUNT_ENV Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2018-01-30Convert CONFIG_SYS_OMAP24_I2C_SLAVE et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_OMAP24_I2C_SLAVE CONFIG_SYS_OMAP24_I2C_SPEED Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Paul Kocialkowski <contact@paulk.fr>
2018-01-22Convert CONFIG_USB_MUSB_OMAP2PLUS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_USB_MUSB_OMAP2PLUS CONFIG_USB_MUSB_AM35X CONFIG_USB_MUSB_DSPS CONFIG_USB_MUSB_PIO_ONLY Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-20Convert CONFIG_NAND_OMAP_GPMC et al and CONFIG_NAND_MXC to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_MXC CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE CONFIG_SYS_NAND_BUSWIDTH_16BIT Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Finish migration of CONFIG_SPL_NAND_SIMPLE, fix some build issues, add CONFIG_NAND_MXC so we can do CONFIG_SYS_NAND_BUSWIDTH_16BIT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-03usb: gadget: usb_ether: Move the interfaces to KconfigMaxime Ripard
We need to select an interface for the usb_ether gadget, and they haven't been converted to Kconfig yet. Add a choice to make sure we have an option selected, and convert all the users. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Convert USB_ETHER to KconfigMaxime Ripard
The USB Ethernet gadget option has not yet been moved to Kconfig, let's deal with that. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Move USBNET_HOST_ADDR to KconfigMaxime Ripard
While the USB Ethernet device address is already defined in Kconfig, the host address isn't. Convert it. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-14Merge branch 'master' of git://git.denx.de/u-boot-rockchipTom Rini
2017-08-13Convert CONFIG_OMAP3_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP3_SPI Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Minor comment tweaks] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-10Convert CONFIG_SYS_I2C_OMAP24XX to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_OMAP24XX Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-09am33xx: Finish migration of CONFIG_AM33XX/AM43XXTom Rini
Almost all users of CONFIG_AM33XX/AM43XX have been migrated. Finish moving the last few over to Kconfig, and put all of the boards under the appropriate Kconfig chocie now. This board choice is non-optional, so remove that keyword on am33xx. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15watchdog: Migrate OMAP_WATCHDOG to KconfigTom Rini
Move this entry to Kconfig. As it is a hardware watchdog, select HW_WATCHDOG. While we could default to enabling this for all platforms, it is currently only enabled by default on AM33XX, so keep that logic today. Cc: Roger Meier <r.meier@siemens.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15gpio: Move OMAP_GPIO to KconfigTom Rini
This driver is used often enough such that we want to have this enabled by default on any ARCH_OMAP2PLUS board, and this only compiles on ARCH_OMAP2PLUS due to required defines, so mark that as the depends. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15TI: Drop 'CONFIG_OMAP'Tom Rini
In the two cases in the code where we use CONFIG_OMAP as a useful test currently we can make use of CONFIG_ARCH_OMAP2PLUS instead. With that changed we can drop all defines of CONFIG_OMAP. While in here, CONFIG_OMAP3430 is only defined and then never used, so drop. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-11configs: am335x_evm: Use omap2 generic spl load scriptLokesh Vutla
No reason to use a separate load script for am33xx than using omap-common load script. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
