path: root/include/configs/shmin.h
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-17sh: boards: Change clock definition of SCIF and TMUNobuhiro Iwamatsu
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to CONFIG_SH_TMU_CLK_FREQ for boards. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2011-02-04Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2011-02-02Minor Coding Style Cleanup.Wolfgang Denk
2011-02-02sh: Remove config.mk for shmin boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-06sh: Add support T-SH7706LSR boardNobuhiro Iwamatsu
This patch supports T-SH7706LSR board. This is constitution almost same as shmin (T-SH7706LAN). Therefore, most functions work by a change of the setting of config. http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706LSR.htm Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-11sh: Add support shmin boardNobuhiro Iwamatsu
This adds support for the SHMIN SH7706 board(T-SH7706LAN). The CPU of this board is SH7706. There are SDRAM of 32M byte, Flash memory of 512K byte, Serial, 10Base Ether and MMC. http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706.htm Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
