path: root/include/configs/sheevaplug.h
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-24ARM: sheevaplug: correct nand partition layoutPeter Korsgaard
Commit 1e3d640316 (ARM: sheevaplug: redefine MTDPARTS) changed the partition layout (without any description why), but didn't change the offset/size to load the kernel from or the root=/dev/mtdblockX in the bootargs. The 3MB forseen for a kernel is furthermore too little. A 4.4 build of mvebu_v5_defconfig is 3.6MB: -rw-r--r-- 1 peko peko 3.6M Jan 16 20:24 uImage.kirkwood-sheevaplug When device tree support for sheevaplug was added to the kernel in commit ee514b381e (ARM: Kirkwood: Add dts files for Sheevaplug and eSATA Sheevaplug) a default flash partition layout (used if mtdparts= isn't passed on the command line / CONFIG_MTD_CMDLINE_PARTS isn't enabled) with 1MB for u-boot / environment, 4MB for the kernel and the rest for the rootfs, so use that layout here and adjust the kernel loading to match. Signed-off-by: Peter Korsgaard <peter@korsgaard.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-03-14ARM: sheevaplug: drop unneded 'usb start' from boot commandPeter Korsgaard
The default bootcommand executes x_bootcmd_usb AFTER loading a kernel from nand and just before executing it, which only slows down boot without adding any functionality - So drop it. Signed-off-by: Peter Korsgaard <peter@korsgaard.com>
2016-03-14ARM: sheevaplug: unbreak kernel bootargs / mtdparts command by dropping ↵Peter Korsgaard
double mtdparts= Commit 1e3d640316 (ARM: sheevaplug: redefine MTDPARTS) prepended mtdparts= to the flash partition information in CONFIG_MTDPARTS, but it is used like "mtdparts=" CONFIG_MTDPARTS - So we end up passing mtdparts=mtdparts=.. to the kernel, confusing the cmdline partition parser. Fix it by dropping the double 'mtdparts='. Signed-off-by: Peter Korsgaard <peter@korsgaard.com>
2016-03-14ARM: sheevaplug: unbreak default environmentPeter Korsgaard
Commit 1e3d640316 (ARM: sheevaplug: redefine MTDPARTS) changed the mtdparts part of the default environment, but dropped the trailing zero termination - So the definition of x_bootcmd_kernel becomes part of the x_bootargs variable. Fix it by reintroducing the zero termination. Signed-off-by: Peter Korsgaard <peter@korsgaard.com>
2015-11-17arm: kirkwood: Move common definitions into common fileQuentin Armitage
Create include/configs/mv-plug-common.h for common definitions for Sheevaplug, Guruplug and Dreamplug. This will make it easier to ensure the built u-boots stay in track with each other Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Use common definition for filesystemsQuentin Armitage
include/configs/mv-common.h brings in the required filesystems if CONFIG_SYS_MVFS is defined, so use it for Sheevaplug and Guruplug. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Move configuration of some commands to _defconfig filesQuentin Armitage
For Marvell plugs, move the configuration of DHCP, NAND/SF, PING and USB commands, and HUSH_PARSER into the _defconfig file, rather than the include/configs/*plug.h files. This avoids compiler warnings of duplicate definitions if the option is selected in the .config, but also defined in the include/configs/*plug.h file. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: standardise the configurationQuentin Armitage
The Marvell plugs are very similar systems, and so it makes sense for their u-boots to have the same commands/configuration. Add EXT4 and MII to Dreamplug, DATE to Guruplug and Sheevaplug. Add CONFIG_SYS_ALT_MEMTEST to Sheevaplug. There are still command differences around NAND, SPI/NOR. Also default to building u-boot.kwb for Sheevaplug and Guruplug. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-02-06kirkwood: sheevaplug: add FDT supportDrEagle
LIBFDT feature is required to support new kernels. Signed-off-by: Gérald Kerma <drEagle@doukki.net> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2015-02-06kirkwood: sheevaplug: fix multiple definesDrEagle
2015-02-06kirkwood: sheevaplug: fix styleDrEagle
2015-01-25kirkwood: sheevaplug: add CONFIG_SYS_GENERIC_BOARD defineLuka Perkov
Signed-off-by: Luka Perkov <luka@openwrt.org> Acked-by: Stefan Roese <sr@denx.de> CC: Prafulla Wadaskar <prafulla@marvell.com>
2014-10-01ARM: sheevaplug: add HUSH parserDrEagle
This patch add HUSH command parser Signed-off-by: Gerald Kerma <drEagle@doukki.net> Changes in v1: - add HUSH command parser Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-10-01ARM: sheevaplug: redefine MTDPARTSDrEagle
This patch redefine MTDPARTS Signed-off-by: Gerald Kerma <drEagle@doukki.net> Changes in v1: - redefine MTDPARTS Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-10-01ARM: sheevaplug: add MTD defaultsDrEagle
This patch add MTDIDS and MTDPARTS defaults settings to sheevaplug Signed-off-by: Gerald Kerma <drEagle@doukki.net> Changes in v1: - add MTDIDS and MTDPARTS default to sheevaplug Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-10-01ARM: sheevaplug: add MVSATA driverDrEagle
This patch add MVSATA driver to sheevaplug Signed-off-by: Gerald Kerma <drEagle@doukki.net> Changes in v1: - add MVSATA driver to sheevaplug - enable ext4 FS support Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-10-01ARM: sheevaplug: change env locationDrEagle
This patch move the environment offset in sheevaplug. The size of the u-boot binary is become too big. Fix saving environments was result of corrupting the u-boot. Signed-off-by: Gerald Kerma <drEagle@doukki.net> Changes in v2: - patch description Changes in v1: - fix sheevaplug environment offset Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2014-08-01ARM: kirkwood: add mvsdio driverDrEagle
This patch add Marvell kirkwood MVSDIO/MMC driver and enable it for Sheevaplugs and OpenRD boards. Signed-off-by: Gerald Kerma <drEagle@doukki.net> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2010-10-13kirkwood: added common config file mv-common.hPrafulla Wadaskar
It is observed that, in most of the board configs the code is being duplicated, also for any common change all board files needs update This issue was under discussion from long on mailing list and we converge on introducing common config file. With this patch- 1. Total Kirkwood specific configuration code is reduced by 210 lines 2. All common configuration can be shared by multiple boards 3. Easy to manage common updates like ARM relocation changes mv-common.h file is added to include/configs/ It contains all common configuration supported for all Kirkwood boards The respective board configs are updated for its usage Build tested for guruplug, mv88f6281gtw_ge, openrd_base, rd6281a and sheevaplug Binary execution tested for sheevaplug Todo: 1. Other custom Kirkwood boards to be synced 2. The support to be extended for Orion5X based boards Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-07-12mvgbe: support SoCs other than kirkwoodAlbert Aribaud
Rename all references to kirkwood in mvgbe symbols throughout the whole codebase. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-04-30configs/sheevaplug: added a few additional commandsFrans Meulenbroeks
This patch includes a few additional commands in the sheevaplug version of u-boot: - support for LONGHELP so you can get help messages - auto completion and command editing - ubi and mii support - ext2 filesystem (convenient if you have an ext2 from which you want to boot) - jffs2 and ubifs filesystems (if you want to use these in NAND) This also makes it more similar to openrd client. Side effect of this patch is that the code now needs 3 sectors i.s.o. 2 so an existing env is overwritten Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-08-09arm: Sheevaplug: Fixed NAND specific warningPrafulla Wadaskar
It is recommended to define the macro CONFIG_SYS_64BIT_VSPRINTF for NAND specific warning removal, same is done in this patch Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-07-18Marvell Sheevaplug Board supportPrafulla Wadaskar
Reference: http://plugcomputer.org/ http://openplug.org/plugwiki/index.php/Das_U-boot_plug_support This patch is tested for- 1. Boot from DRAM/NAND flash 2. File transfer using tftp 3. NAND flash read/write/erase 4. Linux kernel and RFS Boot from NAND 5. Enabled USB PHY init for kernel need 6. Boot from USB supported Note: to boot Kirkwood kernel with USB support, you should add "usb start" in the boot sequence Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
