path: root/include/configs/sh7785lcr.h
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-22net: Move CONFIG_RTL8169 to KconfigBin Meng
Introduce CONFIG_RTL8169 in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Stephen Warren <swaren@nvidia.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2014-01-09sh: sh4: Remove CONFIG_SH4A definition from source codeNobuhiro Iwamatsu
SH4 and SH4A are compatible. But some instructions are different from these. In Linux kernel, It is treated as a separate CPU, but for now, I think that there is no need to divide especially in the U-Boot. This removes CONFIG_SH4A definition from source code, SH4A is treated as SH4. And this fix white space. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: delete redundant CONFIG_SH definitionMasahiro Yamada
CONFIG_SH is defined in arch/sh/config.mk. It is not necessary to define it in each board header config header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-17sh: boards: Change clock definition of SCIF and TMUNobuhiro Iwamatsu
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to CONFIG_SH_TMU_CLK_FREQ for boards. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2012-04-19CMD: Drop CONFIG_CMD_DFL, it's not usedMarek Vasut
$ git grep CMD_DFL board/atc/ti113x.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ board/atc/ti113x.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); board/cpc45/pd67290.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ board/cpc45/pd67290.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); drivers/pcmcia/i82365.c:#define CMD_DFLT (PCI_COMMAND_IO|PCI_COMMAND_MEMORY| \ drivers/pcmcia/i82365.c: pci_writew (s, PCI_COMMAND, CMD_DFLT); include/configs/MBX.h:#define CONFIG_CMD_DFL include/configs/MigoR.h:#define CONFIG_CMD_DFL include/configs/digsy_mtc.h:#define CONFIG_CMD_DFL include/configs/ms7722se.h:#define CONFIG_CMD_DFL include/configs/ms7750se.h:#define CONFIG_CMD_DFL include/configs/r2dplus.h:#define CONFIG_CMD_DFL include/configs/sh7757lcr.h:#define CONFIG_CMD_DFL include/configs/sh7785lcr.h:#define CONFIG_CMD_DFL Signed-off-by: Marek Vasut <marex@denx.de> Cc: Pfister_Werner@intercontrol.de Cc: iwamatsu@nigauri.org Cc: nobuhiro.iwamatsu.yj@renesas.com Cc: vapier@gentoo.org Cc: wd@denx.de Cc: yoshihiro.shimoda.uh@renesas.com Acked-by: Anatolij Gustschin <agust@denx.de> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02sh: Remove config.mk for sh7785lcr boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-11sh: sh7785lcr: Add support zimagebootNobuhiro Iwamatsu
2010-10-21sh: sh7785lcr: Add CONFIG_SH_SDRAM_OFFSETNobuhiro Iwamatsu
2009-07-08sh3/sh4: rename config option TMU_CLK_DIVIDER to CONFIG_SYS_TMU_CLK_DIVJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh3/sh4: fix CONFIG_SYS_HZ to 1000Jean-Christophe PLAGNIOL-VILLARD
2009-03-12sh: Add support 32-Bit Extended Address Mode to sh7785lcrYoshihiro Shimoda
We can built 'make sh7785lcr_32bit_config'. And add new command "pmb" for this mode. This command changes PMB for using 512MB system memory. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-03-12sh: Add some register value configurable to PCI of SH7780Yoshihiro Shimoda
Some register value was hardcoded for System memory size 128MB and memory offset 0x08000000. This patch fixed the problem. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-03-12sh: Add value for PCI system memory registration of sh7785lcrYoshihiro Shimoda
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-28usb.h: use standard __LITTLE_ENDIAN from Linux headersMike Frysinger
Rather than forcing people to define a custom "LITTLEENDIAN", just use the __LITTLE_ENDIAN one from the Linux byteorder headers that every arch is already setting up. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2008-08-31sh: Fix compile error sh7785lcr boardNobuhiro Iwamatsu
This boards used old type preprocessor. This patch fix compile error. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-31sh: Renesas R0P7785LC0011RL board supportNobuhiro Iwamatsu
This board has SH7785, 512MB DDR2-SDRAM, NOR Flash, Graphic, Ethernet, USB, SD, RTC, and I2C controller. This patch supports the following functions: - 128MB DDR2-SDRAM (29-bit address mode only) - NOR Flash - USB host - Ethernet Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
