The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to
CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to
CONFIG_SH_TMU_CLK_FREQ for boards.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
CC: Albert Aribaud <albert.u.boot@aribaud.net>
[trini: Fixup common/cmd_io.c]
with sh_eth
The board with sh_eth needs to set CONFIG_SH_ETHER_PHY_MODE.
And SH7734 needs to set value of CONFIG_SH_ETHER_SH7734_MII.
The new sh_eth driver uses the phy driver. So, this patch enables it.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of
many comments about CONFIG_SYS_GBL_DATA_SIZE.
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the
unnecessary config.mk file.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command
rather than a generic "env" command, or anything else related to the
environment. So, let's make sure the define is named accordingly.
Add CONFIG_NET_MULTI in config file, because sh_eth changed new newwork API.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
rename CFG_FLASH_CFI_DRIVER to CONFIG_FLASH_CFI_DRIVER
move also conditional compilation to Makefile
Add sh_eth support to sh7763rdp.
Disable SH ether driver.
SH7763RDP has SCIF, NOR Flash, Ethernet, USB host, LCDC and MMC.
In this patch, support SCIF, NOR Flash, and Ethernet.
