path: root/include/configs/sh7763rdp.h
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2014-01-08sh: sh4: remove CONFIG_SH4 definition from board configNobuhiro Iwamatsu
CONFIG_SH4 was already defined in arch/sh/sh4/config.mk. This removes CONFIG_SH4 from board config files of SH4. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sh: delete redundant CONFIG_SH definitionMasahiro Yamada
CONFIG_SH is defined in arch/sh/config.mk. It is not necessary to define it in each board header config header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-17sh: boards: Change clock definition of SCIF and TMUNobuhiro Iwamatsu
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to CONFIG_SH_TMU_CLK_FREQ for boards. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2012-05-28sh: Set CONFIG_SH_ETHER_PHY_MODE and CONFIG_SH_ETHER_SH7734_MII to boards ↵Nobuhiro Iwamatsu
with sh_eth The board with sh_eth needs to set CONFIG_SH_ETHER_PHY_MODE. And SH7734 needs to set value of CONFIG_SH_ETHER_SH7734_MII. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-12-02sh7763rdp: change config for new sh_eth driverYoshihiro Shimoda
The new sh_eth driver uses the phy driver. So, this patch enables it. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-02-02sh: Remove config.mk for sh7763rdp boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh3/sh4: rename config option TMU_CLK_DIVIDER to CONFIG_SYS_TMU_CLK_DIVJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh3/sh4: fix CONFIG_SYS_HZ to 1000Jean-Christophe PLAGNIOL-VILLARD
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-24sh: sh7763rdp: Update sh7763rdp configNobuhiro Iwamatsu
Add CONFIG_NET_MULTI in config file, because sh_eth changed new newwork API. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-13serial: move CFG_SCIF_CONSOLE to CONFIG_SCIF_CONSOLEJean-Christophe PLAGNIOL-VILLARD
move also conditional compilation to Makefile Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-09sh: Update sh7763rdp configNobuhiro Iwamatsu
Add sh_eth support to sh7763rdp. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
2008-07-08sh: Fix compile error sh7763rdp boardNobuhiro Iwamatsu
Disable SH ether driver. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-06-09sh: Renesas Solutions SH7763RDP board supportNobuhiro Iwamatsu
SH7763RDP has SCIF, NOR Flash, Ethernet, USB host, LCDC and MMC. In this patch, support SCIF, NOR Flash, and Ethernet. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
