Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC.
Let's create an entry for "config GENERIC_MMC" with "default MMC",
then convert all macro defines in headers to Kconfig. Almost all
of the defines will go away.
I see only two exceptions:
configs/blanche_defconfig
configs/sandbox_noblk_defconfig
They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something
might be wrong with these two boards, so should be checked later.
Anyway, this is the output of the moveconfig tool.
This commit was created as follows:
[1] create a config entry in drivers/mmc/Kconfig
[2] tools/moveconfig.py -r HEAD GENERIC_MMC
[3] manual clean-up of garbage comments in doc/README.* and
include/configs/*.h
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
Signed-off-by: Jagan Teki <jagan@openedev.com>
Commit 7a777f6d6f35 ("mmc: Add generic Kconfig option") created
a Kconfig entry for this option without any actual moves, then
commit 44c798799f66 ("sunxi: Use Kconfig CONFIG_MMC") moved
instances only for SUNXI.
We generally do not like such partial moves. This kind of work
is automated by tools/moveconfig.py, so it is pretty easy to
complete this move.
I am adding "default ARM || PPC || SANDBOX" (suggested by Tom).
This shortens the configs and will ease new board porting.
[1] Edit Kconfig (remove the "depends on", add the "default",
copy the prompt and help message from Linux)
[2] Run 'tools/moveconfig.py -y -s -r HEAD MMC'
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
All SH boards define a checkboard() function which outputs basic board
information on boot, however generic board support requires to define
CONFIG_DISPLAY_BOARDINFO to do that, so define it for the boards.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
By default this undef is a noop, moreover at this point when the
platform support is broken is prevents debugging of U-boot by manual
insertion of #define DEBUG into common files, so it makes sense to
remove the option from all SH boards as a harmful one.
Three supported SH4/SH4A boards with the bootloader image stored on
SPI flash have own flavour of a linker script, in turn they are equal
among each other. The only difference is that the text from
lowlevel_init.o is placed right after start.o, which makes sense.
Note that .bss section is not marked as NOLOAD, because for about
10 years this is a default option of a GNU linker, either the
attribute is found or not the resulting image file is the same.
CONFIG_SYS_CONSOLE_INFO_QUIET
[trini: Make this default n, re-run the migration]
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_CONSOLE_ENV_OVERWRITE
move VERSION_VARIABLE from board config file into a
Kconfig option.
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
This moves SH_32BIT to Kconfig, and removes SH_32BIT from config
files.
SH4 and SH4A are compatible. But some instructions are different from these.
In Linux kernel, It is treated as a separate CPU, but for now, I think that
there is no need to divide especially in the U-Boot.
This removes CONFIG_SH4A definition from source code, SH4A is treated as SH4.
And this fix white space.
CONFIG_SH is defined in arch/sh/config.mk.
It is not necessary to define it in each board
header config header file.
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
The SH7753 EVB board has SH7753, 512MB DDR3-SDRAM, SPI ROM,
Gigabit Ethernet, and eMMC.
This patch support the following functions:
- 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
